Originally posted by Advancedynamix
Pedro the Festiva's build thread.
Charlie, THIS is your slickest fix to dateccasion5:
"I also made a mold to fill my engine mount with 60A durometer Polyurethane. 60A is really soft, so this mount should still absorb a lot of the engine harmonics and vibration, but it will support the engine a little better.
This is an experimental mount. i have 80A and 92A poly as well if I need more support."
No car too fast !
Originally posted by Dragonhealer View PostCharlie, THIS is your slickest fix to dateccasion5:Last edited by Advancedynamix; 03-17-2015, 02:06 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Charlie. you have a link to that poly? I have a nice set of mounts I just made but I think they are a bit on the hard side. I have tried to look up the durometer of the universal poly mounts I used, but have had no luck. Would the stuff you are using be ok to use as a complete fill for a custom mount? Basically could I fill the entire mount with the poly stuff you used or is is that stuff only good to support the existing rubber?-Bryant
It's a must... Charlie, you have to bring Pedro to Madness in October. Just the fact that Pedro will be there could boost attendance to an all time record.
I missed last year but I know I will be sure to show up if Pedro is going to be there. From all the projects that appear to be in progress by members on the forum,
I'll bet there will be several other surprises to be seen at Madness this year too.
Originally posted by Gomez View PostCharlie. you have a link to that poly? I have a nice set of mounts I just made but I think they are a bit on the hard side. I have tried to look up the durometer of the universal poly mounts I used, but have had no luck. Would the stuff you are using be ok to use as a complete fill for a custom mount? Basically could I fill the entire mount with the poly stuff you used or is is that stuff only good to support the existing rubber?
Originally posted by 1990new View PostIt's a must... Charlie, you have to bring Pedro to Madness in October. Just the fact that Pedro will be there could boost attendance to an all time record.
I'll bet there will be several other surprises to be seen at Madness this year too.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Today, I was trying to get over a bit of the flu, and wasn't making much progress on Pedro, but I did get some stuff done.
Check out this whacky contraption that I made from bits I bought from Harbor Freight and Home depot.
Since these B series engines have the oil pump directly connected to the crankshaft, there is no way to prime the engine… until now. We had one of these at one of the race shops I used to work at to prime the Porsche engines because they can't be primed with their own pump either. The one we had was a little fancier and definitely cost a lot more, but this got the job done.
I pumped the oil into the oil pump housing right between the pump and filter. There is a 3/8" pipe threaded hole and plug there that is perfect for priming. I pumped 4 quarts of break in oil through the engine at about 30psi and then put my oil pressure gauge on the engine and cranked it with the plugs out. It had instant oil pressure! Success! It made 50psi cranking with my little Deka battery.
I also did a bunch of wiring today. The engine loom is almost done. Now I just have to wire up the fuel pump relay and a couple relays for the 2 circuits in the engine management. I'll try to get more pictures tomorrow. I was not feeling well today, so I just tried to keep busy the best I could.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I use Napa non detergent 30wt for the first heat cycle on iron block engines. Then I dump it and use 10-30wt Castrol GTX with a fresh wix filter for 500 miles. Then I use synthetic, on engines with chromium top rings ( which the b6 has standard). On engines with a fresh set of iron rings, I'll use the gtx for 2000 miles. This is just my ritual, it has worked pretty good, but may not be the best way to do it. Everyone seems to have a different procedure. I lug the engine for a couple hundred miles too, then beat the snot out of it after a comp test.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Subscribed. My build could use the kind of attention to detail that you put into yours, Charlie, and as such I think I'll slow it down a bit and really put the micrometer into play.In love with a MadScientist!:thumbright:
Charlie, are you using the Festiva thermostat housing on Pedro's engine?Ian
Originally posted by fastivaca View PostCharlie, are you using the Festiva thermostat housing on Pedro's engine?
My upper radiator hose is actually a Festiva lower hose cut to fit. This all clears my Capri airbox without any rubbing. Easy parts replacement and OEM fit and finish.Last edited by Advancedynamix; 03-22-2015, 07:45 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
