Originally posted by Advancedynamix
On a side note can anyone confirm the correct wire to ground to check the timing. I have a no power on throttle issue and double checking with the timing light revealed that the timing was still moving when I thought I had it locked. I had grounded the single yellow and green wire with the black spade connector by the coil. I know it's grounded because the check engine light will come on for 10 seconds after start up and then go out showing no engine codes. But if I check the timing with that wire grounded it will move when the engine is revved? Everything I see says that is the correct wire to ground to set timing.
If I can't get the timing to ground to set base time does anyone know how much advance the ECU will put in for a hot engine at idle? I have an adjustable timing light but I have no idea what timing the ECU is going to be putting in.
