Loolong good man! It's going to be super clean without the exta wiring of efi. Can't wait to see it finished.
'88 L Street/Track Build- Coilovers • B6ZE • Weber DCOE's • Widebody • Chopped Top •
Originally posted by william View PostLoolong good man! It's going to be super clean without the exta wiring of efi. Can't wait to see it finished.Originally posted by Festiva_Fred View PostExcellent work! I love your build!
Thanks guys!! It's going to be awhile before I have time to finish it. We have a big project at work with a tight deadline so I've been staying late to get it done in time.
In the meantime, I bought a pretty clean '89 L with A/C and swapped the suspension from the '88 and have been dailying it. Bought it last Saturday around 2pm, stayed up til 1:30am swapping it, then took it to the Clemson autocross the next day.
As found, it was around back at a used car lot. Had been traded in at the Ford dealership and the car lot bought it from them.
Cleaned up.
Swapped.
Still on the paper tag... autocrossed it less than 24 hours after buying it lol.
'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Looks great John! Video looks good. How was the time?Last edited by Team Lightning; 11-09-2017, 08:24 PM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I didn't get there early enough to walk the track so I was struggling with the course layout all day. I bumped the timing up after my second run which made it easier to overdrive the car, so that didn't help either. Fastest time of the day overall was 50.652, my fastest timed run was a 55.935 which put me slightly quicker than middle of the pack. I made two fun runs afterward (didn't count as a timed run) and ran a 54.752. I didn't grind flat spots on the knuckles like I did on my '88 so it doesn't have quite as much camber up front as it needs, but it was sticking pretty good anyways.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Not really, I just keep a constant check on Craigslist, Facebook, and offerup. Most are pretty beat.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Over the past couple of years there seems to be quite a few clean ones coming out of Tampa area. There is where I got my White and Yellow cars."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Did you end up getting the header working??
:edit:
I read through this thread last night at 2 am.. i retained the part where you bought a header, then forgot you got it on hahahLast edited by Thebrandonbeezy; 04-04-2018, 08:15 PM.CURRENT. Past
88 festiva L. 89 xr4ti
14 foST. 89 xr4ti
82 F100. 97 silverado
82 GS1000. 06 h3
82 GS750. 79 ta 6.6
74 TC185. 89 turbo katana 600
69 T500. 80 gs1000
15 sonic 82 cr480r
Originally posted by Thebrandonbeezy View PostDid you end up getting the header working??
:edit:
Yeah, its fitted and welded up. I cleaned up the weld splatter this weekend to prep if for ceramic coating. Found another slight issue... I test fit the header/flange back when I had the b6d pan on; one of the tubes sticking out of the B6t pan hits the collector flange so I'll remove the tube from the pan. I still need to modify the pipes that go under the pan.
I'm finishing up a big project at work this month, so I'm planning on getting started back on this thing to finish the swap after that.Last edited by theastronaut; 04-04-2018, 08:27 PM.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Originally posted by Thebrandonbeezy View PostOk so thats the accord header still?
Also will that clear the ac compressor?
Last edited by theastronaut; 04-04-2018, 09:03 PM.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
perfect!
one more question, the b6d block has the oil feed for turbo like the b6t? also coolant?
guess thats 2 haha
i cant wait to see this running, got me wanting to do bike carbs on mine until i track down an e153CURRENT. Past
14 foST. 89 xr4ti
82 GS1000. 06 h3
82 GS750. 79 ta 6.6
69 T500. 80 gs1000
15 sonic 82 cr480r
Yeah the blocks are identical. Oil pans are different. I wish I had done bike carbs instead of an Escort carb on my '89.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
