Originally posted by Advancedynamix
'88 L Street/Track Build- Coilovers • B6ZE • Weber DCOE's • Widebody • Chopped Top •
'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
'89 L B3-5 speed-A/C-Advanced Suspension
Project Goldilocks '66 C10 Short Fleet BBW Build
'65 C10 Highly Detailed Stock Restoration Thread
'55 International Metal/Body/Paint Work
'66 F100 Full Rotisserie Restoration
'40 Packard 120 Convertible Coupe Restoration
How To Restore and Detail an Original Gauge Cluster
How To Detail Sand Body Panels, Edges, Corners
Originally posted by theastronaut View PostI've noticed that the springs would bind and pop on very tight turns but it hasn't been much of an issue... it's so little that I rarely have to turn that tight to maneuver the car around. So I need something like these:
Like these have. I also put a washer between the spring hat and the strut bearing to distribute the load on the aluminum better.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by theastronaut View PostDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View Post
Originally posted by Advancedynamix View PostAwesome! 2 of these in two weeks bought by festiva owners. Where are you guys finding this stuff? I looked for one of those for over a year with no luck.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Dug the Webers out of storage so I could take some measurements...
That and I really just wanted to see the Webers mounted on the Miata motor. :love10:
Roughly 10" from the intake flange to the tip of the stacks. Filter housings will be another ~1" taller.
Measuring the distance between the firewall and the stock B3's intake flange. Roughly 9.75". I'll need the extra space from moving the B6 forward.
Since it's July and I was already driving around in the yard... :usa2:
I've been dreaming of this type of build for years. It's awesome to see it coming to life!
We moved the engine 2.125" forward on our LeMons car with the g15mr tranny. That gives you just enough space for your filter.Last edited by Advancedynamix; 07-12-2016, 07:57 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I need a tissue.Any difference that makes no difference is no difference.
Originally posted by Advancedynamix View PostI've been dreaming of this type of build for years. It's awesome to see it coming to life!
Originally posted by Advancedynamix View Post'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Originally posted by dliverance View PostAstronaut, I may have a lead on dohc 1.6l headers for fwd. I should know tomorrow. Also, do you have to use the trumpets or no? There's some filter assemblies that would save you a bit more room.
Originally posted by sketchman View PostI need a tissue.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
Poked around under the hood of the Capri for about 15 minutes tonight to get an idea of what all needs to be disassembled to get the motor out. There's a ton of stuff under there... :shock: Going with carbs and stand alone ignition will really clean things up.
Will I be better off to pull just the motor, or the motor and trans together?
Got more stuff removed this afternoon. I think it's pretty much ready except for the clutch cable, a/c lines, one heater hose, axles, shifter, and the starter wires. Some of that will be easier to access once it's loose and lifted up a little I think. Need to tow it to the shop so I can do it on concrete instead of out in the field it's in now.
