Hey gang,
I'm Rob and just thought I'd say a bit about myself and post a few pics. My way of gaining emotional leverage for when I call on people's assistance
So I just scored a neatish 3dr Mazda 121 with 4 months rego 304000kms carby 5 speed with aircon bald 12" tyres a stench of burning oil when floored and a brake pedal that goes to the floor. I'm quite fond of the little buzz box, reminds me of my EJ-VE powered L200 Mira
Need to fix brakes so just picked up an even cheaper 5dr Ford Festiva GLXi.. Which I guess would be a whizz bang top of the wozza Ford Aspire if I wasn't in the land of oz
1.5 EFI 202000kms, new radiator, master cylinder, timing belt changed recently... No oil showing on dipstick and it's a bit rattly. I suppose I'll have to stick some oil in it and see what it sounds like and where the oil is leaking from, hopefully it isn't burning it
Plan is:
Aspire brake/rear axle swap with standard 121/Festiva springs with 1.5 coils chopped off or aspire springs with ??? coils chopped off on Festiva or Aspire front struts?
Aspire master cylinder + brake booster. Lines on opposite sides so I'll have to bend them, I'm assuming booster bolts up.. My master cylinder is stuffed so I need to make this work
Then if engine is good: engine, wiring harness, ecu, fuel tank etc full efi conversion into mine.. I looked at rockauto and the dimensions listed for aspire and Festiva fuel tanks are the same.. Although 5 door aspire is listed as a different part, so I'm not sure if I'll be able to fit the tank or see if the sender with pump will swap into my tank, hopefully fuel lines are adequate.
I should be able to keep aircon and I'm not sure if I can or want to swap the power steering.
Does anyone know of any other random bits and pieces are worth swapping? I won't swap the sway bar but all my bushes are stuffed so I'll swap the LCAs and such on the assumption they're the same
Once I get to this stage I'll need to decide between xr2i B6T, protege BP+T or KL. I guess if I need xr2 axles I should get a xr2 parts car and use B6T as a stepping stone. Need to figure out technicalitys of turbo/non turbo gearbox and axles that people say to use in the writeups
I just realised I typed this all out on my phone and I can't upload my pics, I'll take some with a real camera tomorrow and post them up.
I openly look forward to all comments and criticisms
Regards,
Rob
Plan is:
Regards,
Rob
