1988 323 Station Wagon KLG4 swap
  • 1988 323 Station Wagon KLG4 swap
    I recently purchased myself a 1988 323 Wagon, it has been mechanically converted to a GT with the rear disk brakes, sway bars, and of course the B6T
    The plan for it is to get it running and plated with the B6T then later I'll pull it out and swap in a KLG4 with a turbo, 5 lug conversion and get it riding nice and low
    It was in the beginning stages of being parted out so it didn't run when I picked it up but was told it shouldn't take too much work to get fired back up again
    Here's a few pics from when I picked it up
    And a bunch of spare parts to go with it
    It also had 4 garbage tires on it which can somewhat be seen in this pic
    Before I started putting a face back on it I wanted to test fit my festiva ATH front bumper on it, it fits beautifully if I choose to use it
    After a set of tires I was able to roll it out of the garage for a quick photo shoot and to clean up the garage before I get started on fixing it up
    My collection of spare parts
    First disgnoses showed it has spark but no fuel pressure, so digging further I found out that the fuel pump was dead
    So it's a perfect time for an upgrade with a walbro 255lph pump
    Along with a new sending unit and gas tank
    The old, beat gas tank with the remains of a mouse nest that was on top of the tank
    New tank ready to go in
    But after getting fuel pressure to the fuel rail, it still won't fire up, checking things out I found out it lost spark..... Ugh
    So I didn't bother putting much effort into getting the B6T running since I wanted a KLG4 in there anyway, so I picked up my donor cat
    A 2000 626 with a 5 speed
    The goods
    And it's almost ready to come out
    KLG4 is out
    Pulled the B6T out
    Since I've worked on KL's in tight engine bays before, I counted on having clearance issues with the KLG4 intake/throttle body and master cylinder and since this engine bay has more room in it then my old festiva, I figured if there's enough room to work with, I'll move the engine forward to clear the MC so it was time for a test fit so I can see exactly what I'm working with
    And like I anticipated the throttle linkage interferes with the MC
    It looks like I can move the engine forward by 2-1/2 inches and I should still have enough room for the rad
    The flex pipe on the Y-pipe needed to be replaced so I figured to also add a V-band clamp to make life easier down the road
    Hydraulic clutch conversion using GTX parts
    When I did the diff swap in the festive I learned of a thickness difference in the ring/pinion gears between the B6T/BP G series vs the KL G series which does not allow the complete internal gear sets to interchange
    And since there was a difference in final drive gear ratios I couldn't simply drop in the 26 diff to the KL trans so I ended up separating ring gears and bolting the KL ring gear to the 26 spline diff..... That proved un-reliable in the long run
    For this project I don't want to go with an Mfactory because I didn't like how it felt to drive in the festiva so I started using my brain at what options I have to run an open differential and retain the factory rivets
    So knowing KL trans either came with a 4.10 or 4.38 final drive, I got thinking about what 26 spline G series had a 4.10 final drive.... The BP trans..... So tonight I picked one up and got to work
    After pulling both transmissions apart, I confirmed they had identical final drive gear ratios
    The BP ring gear is not as thick as the KL ring gear but I don't think it will cause a problem since the gear ratios match
    I was really happy how that turned out so I started the re-assembly
    Today I re-threaded the holes in the block for my intermediate shaft mounting plate I made and installed it
    When I bought the 626 the owner said it leaked a lot of oil.... So I ordered new valve cover gaskets which arrived today, so I got those replaced as well
    The previous owner of the wagon must have had trouble at some point with the crossmember bolts because the front was welded directly to the lower rad support
    So while the engine is out I decided to cut it off so I can make the proper repairs to both the crossmember and the lower rad support
    In the process of removing the crossmember I also found the rear bolts were rusted pretty good to the point where I need to basically replace all 4 captive nuts to properly re-attach the crossmember
    So today I ground off all the welds on the crossmember, drilled out the mounting holes again (they were full of welds) and re-inforced the ground down areas
    Next job is to replace the captive nuts.... ****
    Captive nut repairs... Ugh....
    I found that some mice once made a home in the cavity for the rear captive nuts
    Before I start making motor mounts I wanted to clean up the surface rust from the engine bay, looks pretty ****ty
    Then found a rust hole in the strut tower and after having both strut towers on my GT separate, I decided to fix the problem before it becomes a bigger problem
    The paint that I picked up doesn't quite match the exterior, but it's close enough lol
    Got the mounts made up tonight
    I couldn't live with the baby blue, I had to darken it up with some navy blue instead
    Also freshened up the engine and got the harness attached so I can start sorting through the harness to get it prepped for splicing into the wagon
    Some prep/tidy up work on the harness tonight
    And hopefully the last install of the engine
    So progress has been steady, parts have come in the mail etc first was a new idler pulley for a PS pump delete which I also trimmed the bracket for a cleaner look
    But the belt I ordered was too big so I need to order a shorter one to finish up the install
    Also got some new plug wires
    Pulled the old shifter linkage out and replaced with a much cleaner set
    Axles installed, clutch hydraulic lines installed and bled out
    And tonight was fitting the VW rad in the support and making the mounting points etc
    Plenty of room left for a fan lol
    Next is exhaust work
    And the first start up video!!! WOOT!!
    And now to address the clearance issue between the throttle body and brake fluid reservoir
      O
      M
      G
      So much want!!!! That's beautiful.
        Fantastic writeup/pics. Festiva of the Month, just because.
          I like it!
            That thing is awesome. I wish I would find a 323 wagon around here its the closest thing to a festiva wagon I'll ever get.
            Great work as always.
            Now for some 18s and low!
              Gorgeous.
                Great job! This is awesome!
                  What's nice too is that even the gen1 323's engine bay is larger than a Festiva's. More clearance to the firewall, and possibly a little wider.
                    This. Is. Awesome!
                    Probably the only car I'd be jealous of on the road. Like William said closest thing to a festy wagon we could get. Glad to see your taking such lengths to make it nice!
                      Very nice!
                        Thanks guys, so far this project has been a lot of fun to do but it's not quite finished yet
                        I still need to bleed out the brakes and finish up the cooling system before the first test drive, I've owned the thing for close to a year and still haven't really drove it lol
                          I think you need to bring that to FM10!
                          ~Nate
                          Current cars:
                          FOTY 2008 winner!
                            +1
                              I do want to make another madness meet but not sure when I'll be able to make it down
                              Yesterday I got the brakes bled and working on the wagon and got started on the coolant piping, once that's finished, it's drive time lol
