Originally posted by dliverance
Just another build thread
I've been making some awesome progress. I got the fuel system complete and now I'm working on the electrical. From the looks of it, I can eliminate 75% of the wiring so I'm going to tuck it all in the fender for now. I made up my mounting bracket for the fuse/relay block today and I'll be installing that pretty soon. Other than that all she needs to run is cooling line plumbing for the radiator and heater, carb rebuild, electrical and some vacuum lines.
The next local event is April 23rd and I'm really hoping to run that event. Especially since the next event after that is the 30th.
Slowly but surelyOriginally posted by Advancedynamix View PostIt's so close!
I'm super excited. I can't wait.Originally posted by wwwdotgov View PostThe engine looks so good in the bay. And looks like pretty good carb clearance too. Should be a blast to drive!
Right now The car is waiting for very few things. I'm waiting for my job to finish installing their sandblaster so I can blast and rebuild the carbs, I still need to run all of the vacuum lines for the brake booster and distributor, I need to finish my coolant lines for the heater core and radiator and I need to do the exhaust. I'm also working on the battery tray right now. I've decided on an odyssey pc545. It's a good fit and it has standard terminals.
I got the wiring just about finished. All that's left is the thermostat temp sensor, a new connector for the radiator fan and permanently installing the distributor wiring. All of which can be done pretty quickly.
here's some pics of the battery tray and wiring in progress. Sorry for the crappy pictures. Once it's all cleaned up I'll try to snap some decent ones with the dslr.
Thank you. The progress is slow but it's steady. I feel like I'm so close but still a million miles away. This week I plan on rebuilding the carbs and finishing the radiator hoses. After that, I just need to add fluids then start it up and tune the carbs.Originally posted by festyfreak39 View PostLooks great man
Sent from my SM-G930W8 using Tapatalk
Last edited by Advancedynamix; 04-04-2017, 01:05 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
!?!?! Where'd you get that? And how much larger is it over stock?Trees aren't kind to me...
Made it. It's 60mm, which is 4mm larger than the typical 4 rib Mazda pulley. It ends up being the same drive ratio as the big shaft (capri) v belt alternator.Originally posted by FestYboy View Post!?!?! Where'd you get that? And how much larger is it over stock?
The typical 4 rib pulley would overdrive the alternator, and that isn't a good plan on an engine with Webber's and no rev limit.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
