Thanks Astronaut. The second top hat is on its way. I had to order them from different vendors.
Just another build thread
I brought the front parts in to work today so I could mod them on the mill. I ended up taking charlies advice and bringing up the bottom hole instead of reworking the top hole. It took about 5 minutes each to open them up. With this I should be able to adjust camber with the original hole and I didn't chew up the mount that much. If I ever need more camber I'll just slot the top more.
Also I chose the emusa coilovers because the flange is flat. Makes it easier to work on.
Yay parts! My order from the festiva store came in. I also finished up the fronts for the coilovers. Now all i need is to make the rear top hats. If i can't get it done by mext friday I'll use the stock stuff. After that it's body work time. I'm guessing the junspeed parts will be here on time for that.
The rears are in! I had a bit of a rough week with the festiva. Last Sunday I went out to play some pool and on my way home she ran out of gas. I must've spaced out on that one. While I was waiting for the gf to come, I slammed the door a little bit too aggressively and broke the drivers window. That's fixed too but it was a little bit annoying.
I got the car set at a pretty low height right now but it seems to handle just fine. Either tonight or tomorrow I'm going to do a mountain run and see just what she can handle.
I was a little bit worried about the tires rubbing so i rolled the rears but it doesn't look like I'll have any issues. In the future I'm going to set it up with about 2 degrees of camber. Maybe more. Who knows.
With the wheels and suspension done, I can focus on the body for a little bit. Right now it leaves a bit to be desired. The windshield is broken, theres dents here and there and the paint is just rough all around. I'm hoping to have it at least primed by next weekend. I cant paint until my junspeed parts arrive. I'll get the new lamps and mud flaps installed then too.
Didn't those front coilovers come with top hats? You'll want to run those. The spring shouldn't rest on the strut mount.Originally posted by dliverance View PostDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I ended up starting the paint process a little bit early. This weekend I put in about 40 hours of labor into the festiva (thursday-monday). Right now it's sitting in my garage primed and masked but I have a few areas that need a little bit more attention before paint. Hopefully I'll have some painted pictures soon.
I was supposed to paint today but I decided to prime it one more time just to be safe. I went with a high build primer this time to fill any small imperfections. next step is fine grit sanding and paint. BTW the hood, roof and hatch are already painted. The hardest part of the body work was the dent on the drivers door, the massive dent on the passenger rear quarter and the grind marks from the weld repair of the fender flare holes.
