I guess at their events you race their cars? If so what 1/4 mile times do they run?
OverKILL!
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Originally posted by mikemounlio View PostI guess at their events you race their cars? If so what 1/4 mile times do they run?Last edited by TWFodor; 06-30-2017, 08:02 AM.1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
You can follow me on instagram @twfodor
It looks like a fun event tho. My car is not setup to do drag racing tho.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I might just get some time to play with the car tonight. I still need to finish the other front strut and get it mounted then start over on ride height. Also i want to install my dual boost controler and my water meth this weekend. Gott get the car ready fo the race next weekend.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Well i didnt get time for overkill this weekend. I was working on the houses most of the time. I will be doing some much need race prep tonight tho. The next race is this coming Sunday. I want the car fully ready saturday night loaded on the trailer and all. I hope to have the following completed by then (in no order)
1. dual boost controller on and set
2. water meth kit installed and set
3. front strut installed
4. ride height set
5. camber and tow finally setup
6. install both corbeau seats (not waiting on my seats anymore) gonna install the good ones in the mean time.
7. install the push button kit
8. make some kind of column gaurd (just for looks)
So knowing my luck i will almost finish one of the above but i will intend to finish it all.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I got the new strut on OverKILL! Lits of room now. I still used one spacer to make sure i had room for flexing of componets.
I have added my weight to the drivers seat and my passengers weight to the other seat. Tonight i start fine tuning the ride height front and rear. Once thats good ill adjust toe in front and hope rear toe is good.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Last night i got the front end pretty decent as far as ride height goes. My toe is a bit out now. I am up to the nut on the tie rod arm so i will have to pull them out and trim down the tie rod end a bit to make room to allow for more toe. Also i have to finish the rear end. I have nates 1st run of camber plates. So i dont have as much adjustment in them as they have now but i will be able to work with it. Really all that i can do is set the rear height until i have the proper toe and that will be as goo as i can do for now.
So we still have another day or two in the setup until its good to go. I have to set up my push button and my water meth at the least as well. Also i must install the race seats before sunday!
Took a small drive last night and wow is the car different. I have never gotten this low before. I have right under 1" of drop from the LCA pivot to ball. The rear was close. Had a bit of toe but it was ok for a test run. What a test run it was!
The car handles way different then it ever has. The turn in felt super light and very quick. My out of wack toe i would think is the cause of the wheel wanting to just snap to one side or the other. With just a trip around the block i can feel how out the suspension was compared to how it is now. I cant wait to get my toe set right and my seats in the car.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
If the car is toe out, you don't touch the inner tierods, just back them.out of the outers, that will push your toe back in.Last edited by FestYboy; 07-13-2017, 08:16 AM.Trees aren't kind to me...
Mike with the front lca pivot to ball around 5/8-3/4" and the body level you should still be ok with those plates. At least on chris's car it is. I think you both have aspire beam with festy mounts. The additional adjustment is for people running higher.
Sent from my LGLS755 using Tapatalk~Nate
Current cars:
FOTY 2008 winner!
I have just slight to much toe in on drivers side and a visible amount of toe in on the passengers side. I have the locking nuts on the last thread and they are touching. So i need to trim the TRE back a bit more to allow for the bar to slide in more giving me toe toe out.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Originally posted by skeeters_keeper View PostMike with the front lca pivot to ball around 5/8-3/4" and the body level you should still be ok with those plates. At least on chris's car it is. I think you both have aspire beam with festy mounts. The additional adjustment is for people running higher.
I was having an issue getting my two LCA pivot points the same height. I dont know if the frame is just bent up a bit or if it was my welding or what. I will be working on it again tonight tho. Now that i am close i will tweak by tweak my way to shape.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Its a slow and painful process, but sounds like you are getting there! Chris's rear is probably 1/4" below the top of the sleeve.
Current cars:
FOTY 2008 winner!
Originally posted by skeeters_keeper View PostIts a slow and painful process, but sounds like you are getting there! Chris's rear is probably 1/4" below the top of the sleeve.
Sent from my LGLS755 using Tapatalk1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
My front ride height is about as good as i can make it. The LCA pivit point is the same height side to side with my weight in the car. The rear is all kinds of different tho. The right side is at the top of the travel of adjustment. The left side is down like 1" half a tank of gas my weight 180LBS and my rider close to 200lbs. the rest of the car is gutted as you know. I still need to adjust toe in the front but i should have that done today. Also tonight i will wire in my push button starter hook up my meth kit. Maybe Saturday i can install my seats and belts and do a giant bolt check. I really want to get all my races in this time.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
