Alice and The Festicle
  • Alice and The Festicle
    Doing this a bit late, but I'm gonna just do a quick catch up.
    Bought her the day before my birthday in 2015
    Had a lot of fun with her
    And eventually wrecked her. That's kind of my thing with cars. I have undoubtedly the worst driving record
    Anyway, I got to work righting my wrongs
    In the process of looking for a donor, I found this little gem my friends loving named "The Festicle". I also found it quite suiting
    PO said it was leaking oil into the cooling system. What I make of that is he had a bad head gasket, replaced it, forgot to flush out the heater core, and oil flowed back in to the system from there, because in my rebuild, I pressure tested the block and head and they checked out ok.
    Anyway, I've just finished painting and about to begin assembly.
    A mechanic knows how; A technician knows why.
    Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
    Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
    Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
    FB Festiva page: Jared Bennett
    Instagram: jaredbear82
      LooKing Good!
      '88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
      '93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
      '91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
        Very nice!
        Sent from my XT1585 using Tapatalk
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        Aspire brake swapped
        stripped and sold due to rust
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
          Just began stripping The Festicle for paint prep. The plan was to strip it down to the bones so I wouldn't really need to mask anything, but then I realized I should ask, What Hard-ToFind, non-reusable things (such as adhesive foam pads and fragile clips) should I mask off, instead of removing the items held on by such?
            Things that infuriate me:
              Almost done stripping the interior on The Festicle
              I've decided I'll paint it white, since that's how it came from the factory
                Are these brackets structural? Or are they just for mounting the front seats? I'm quite tall, so I would like to mount my seat as low as possible, but they might be in the way. I would like to remove or alter them if they are.
                  They are for keeping the intrusion of a side impact less. I would keep them. Or get rid of them and replace with something stronger.
                    Yes those are structural. They tie directly to the door sill and keep the floor from sagging.
                      Would it be a good idea to make two more trusses for each side (left/right), place them on each side of the factory trusses (front/back), and then remove the factory ones? My new ones would probably of slightly thicker steel, but lower profile to allow more room. I think that would be stronger with lateral crush without adding too much twist resistance for chassis flex
                        If you can tie the new ones in first, that should do the trick. You could also U channel from the subframe laterally to the tunnel and then to the pinch weld. But for/aft placement would need serious consideration.
                          I don't know that I'm quite to the level of constructing a welding in a U channel without warpage, but I can certainly attach new ones with spotwelds like the old ones.
                            So I can find this later:
                              Just pressure washed the engine bay
                              Some rust on the LL rails from the battery.
                              How should I go about cleaning this up? Paint stripper, rinse, scrub with water and baking soda, apply POR15 rust inhibitor, then paint?
                              Also, starting to find rust in the seams.
                              Suggestions? Thanks guys
