My future plans ( as in this week, the next event is April 7th) is an aspire beam, aspire brakes and 13" wheels. I need to run 13s to get readily available race tires that fit and doing raise the ride height of the car (21.5" o.d.) . I'm going to raise my spring rate to 150 from 120 in the rear for the race tires. I'll bring 250lb springs to try for the front, but I doubt I'll need them since the front worked awesome.
long term plans include wilwood calipers ( mostly for cheap performance pads that are easy to get) all the way around and a completely revamped engine. A monster b6t that will devour those vettes
Current chassis mods are simply coilovers, Capri brakes in the front, harness bar, and reinforced removable front lower radiator support and aspire control arms. I also made my own upper strut mounts that are like Rio mounts, but they lower the car .750" .
I have no interior in the back of the car, removed factory seatbelts, a/c and anything else that's not necessary ( no radio ect.) I'm running 200lb front springs and 120lb rear. This setup is magic with street tires, it's very balanced and you will destroy the street tires with confidence. I had best luck with 1/8" toe out front neutral toe in the back and -2 degrees camber on all 4 wheels.
