Field Trip!
  • #31
    yup.. see what I mean about the tie rod end? It's like a adapter or something.... does it look to be a SHO tire rod end with a thred adapter on the end sizing down to a Festi Rack?
    93 Mustang LX Coupe 54K 347 S-Trim 515 RWHP **Stock apearence**
    92 Ford Ranger XLT 331-T-Trim, TKO 3550 13"Wilwoods, 17" Cobra's, B-II Sway Bar Mod, Explorer front bar.
    91 Ford Festiva GL 30K orgional - soon to be cut to pieces!
    • #32
      Its looks like a shortened taurus tie rod end. They may have cut it to festiva length and put a helicoil in it to bring it down to the festiva smaller tir rod diameter.
      SHO
      Festiva
      The aspire tie rod has a little large tapered shaft were it goes into the spindle but screws onto the Festiva tie rod itself.
      I was afraid to use the helicoil method but Im sure it would work. I just used the aspire tie rod with a taper bushing. In hind site since I was making a bushing I could have just used the cheaper Festiva tie rod.
      SHO valve springs............
      Doug Lewis
      shoguy89@aol.com
      Ford Performance Specialists Inc.
      Atlanta Georgia
      770-949-7191
      2001 F-250 Powerstroke-
      Garrett turbo - 700ft-lbs
      1996 TR SHO-
      Long tubes - bottle fed - low and fast
      1989 CR SHO-
      Shaftdrive supercharger - 400hp
      money pit
      No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
      • #33
        It looks like he has 5-bolt wheels on there, but the car looks like it still only has the 4-bolt posts.
        • #34
          After some Massive searching... I think I got it!
          Here are the plates he had on the car... Very nice piece! At the time I didnt see a name, but going back and looking at the pictures I saw a name of sorts...
          I could make out the CUS but nothing else on the pictures
          I fount this thread....
          Cusco's???
          • #35
            Found lots of links for them but most showed a generic picture. It would be possible to get a set of universal camber plates and cut them to the sahpe / bolt spacing of the festiva factory mount (?)
            money pit
            • #36
              I'm guessing that caster is not an ishue on Festi's sence they went with camber plates only? I'm not that up on this part of a setup so please any one chime in? I did find this nice set of plates, but they look to be a bit much in the way of adjustment for a street car... Nice for setting up a street / and race setup with out re-doing your allignment....
              • #37
                Originally posted by URTOAST
                I like them! They look like the ones for the rear of the car..
                I'm guessing that caster is not an ishue on Festi's sence they went with camber plates only? I'm not that up on this part of a setup so please any one chime in? I did find this nice set of plates, but they look to be a bit much in the way of adjustment for a street car... Nice for setting up a street / and race setup with out re-doing your allignment....every time!
                http://www.pde-usa.com/parts/frontcamber.htm#
                • #38
                  I think they layed a stock festiva strut bushing on top and cut it out to fit .
                  money pit
                  • #39
                    it sure looks like it... I'm hoping to try something new.. that just looks trashy to me
                    • #40
                      I noticed some markings on the spring
                      8/90.... that would be close to the car build date (?) It was based on a 1991 Festiva correct?
                      1000.250.150
                      10.00" length 2.50 " diameter 150 LBS per inch
                      money pit
                      • #41
                        It's a 90 model by VIN and old Ebay listing.... I talked to MOOG today and got all of the demensions of the Festi and SHO tie rods.... nothing out of the Billions of parts they make matched up, so they must have "invented" the part...
                        FYI
                        Festiva Outer tie rod thred female Metric 12 x 1.25
                        SHO outer Tie Rod end taper .525 (MIN)
                        .626 ( MAX) ( TAPER RATE) 2 inches per foot.
                        Yet again more worthless info provided by me I'm getting good at finding the facts out, then deciding that the way they did it was .... um well less then what I expected from a bunch of Ford Engineers.
                        I'm thinking about eather reaming out the spindle to a size I can work with, or working on the inner tie rod.... Using the Festi one is probably fine, but thoughts of running large rubber, and a large wheel on a smalish rod makes me wonder about making the conversion at the Rack end of things, and get a larger bar for it... less bumpy bump if you know what I mean... Thats Fridays mision... see if I can get that info!
                        • #42
                          The concept has always intriged me but I would have to do something with the tail lights . . . they just never have looked right to me . . . definately needs customs
                          92 GL - parts car
                          97 aspire - parts car
                          87 323 DX - daily driver
