Got a 90 festiva, trying to take rear wheel off to replace tire. removed the four lugs, tire still won't budge. There's some rust, and short of beating the crap out of the wheel i don't know what to do. any suggestions?
rear tire
When you put it back on I suggest using some grease or anti-sieze around the hub where the rim fits over. This will prevent future problems.
matt
Try this:
set the parking brake. with the lug bolts off, and the center "cutesy cap" off (if it has one), try using some long lever or bar, and turn the rim. See if it will maybe break loose that way...
have someone put weight on the lever, and whack that rim. There should be no other reason (other than rust) as to why this rim will not come off.
Good luck!
SBFamous Last Words: "How hard can it be?"
Drive it really slow with the flat tire and the lugnuts loose a couple of turns. It wont hurt the rim, if anything it will hurt the tire, but probably not even the tire if you move slow.The Festiva Store
Re: rear tire
Think in terms of heat, vibration, force-leverage. Usually works. Sometimes by themselves, sometimes in conjunction with another.Originally posted by synapzeGot a 90 festiva, trying to take rear wheel off to replace tire. removed the four lugs, tire still won't budge. There's some rust, and short of beating the crap out of the wheel i don't know what to do. any suggestions?Rich Norman
5 Festivas:
1992 L - Daily Driver
1993 GL-Off-Road Buggy Subaru EJ20DET
1988 L - Big Block Ford Pro-Street
1992 L - Corvette LS7 drivetrain
1991 L - Parts Car
