Anyone know where i can get new brake levers? Does FMS have them? The lever that is in the rear drum brakes that the parking cable attaches to. Every single one that I have worked on has been stuck pretty good and when I do get them "loose" they stick up again in no time.
Where can I get new rear brake levers?
The Festiva Store
Specializing in restoration, tuning and custom parts.Tags: None
Don't know if they are available new anymore!
But, after i "break them loose" and get then freely flexible with PB Blaster, I use a solid lub like graphite or molybdenum disulfide worked into the joint keep them from freezing up again after install.Last edited by Pu241; 11-25-2008, 04:14 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Mine were frozen when I got my car 6yrs ago,after I freed and lubed them up have not had a problem since,but I pull my rear wheels once a year to check and repack wheel bearings,and also lube all moving parts.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
Ben,
Take a propane torch and heat the living crap out of them. Then PB Blast them and hammer them until they come loose. Then take some of that handy dandy anti-seize, which we all know you use on every bolt so you don't have these same headaches in the future, apply a light coat between the metals and viola!
Let me rephrase that. If I were having the same problems you are having, and I have, I would do the above, which I have. Not telling you to in case there are problems.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
problems? what problems?Trees aren't kind to me...
I soaked mine in a product called "Release-all" for about 10 or 15 minutes and that freed them up. Once that was done I worked some brake lube into the joint and then reinstalled them. Haven't had a problem since.Ian
I believe festiva and aspire ones are different since they are different size brakes. Also I called FMS and they said they have the left ones in stock right now and should get the right ones sometime next month. They are $40/piece.The Festiva Store
