Where can I get new rear brake levers?
  • Where can I get new rear brake levers?
    Anyone know where i can get new brake levers? Does FMS have them? The lever that is in the rear drum brakes that the parking cable attaches to. Every single one that I have worked on has been stuck pretty good and when I do get them "loose" they stick up again in no time.
    The Festiva Store
    Don't know if they are available new anymore!
    But, after i "break them loose" and get then freely flexible with PB Blaster, I use a solid lub like graphite or molybdenum disulfide worked into the joint keep them from freezing up again after install.
      Mine were frozen when I got my car 6yrs ago,after I freed and lubed them up have not had a problem since,but I pull my rear wheels once a year to check and repack wheel bearings,and also lube all moving parts.
      99 Dodge Caravan SE
      95 Taurus SHO auto 265hp
      94 F150 351W auto (for sale)
      95 Honda 1500 Goldwing SE
      95 Iszuzu Trooper LS
        Did you try to clean them with muriatic acid? Then paint them with some epoxy primer or have them re-plated.
        Joe Lutz
        The SKATE ..... 1992L 5spd
          Ben,
          Take a propane torch and heat the living crap out of them. Then PB Blast them and hammer them until they come loose. Then take some of that handy dandy anti-seize, which we all know you use on every bolt so you don't have these same headaches in the future, apply a light coat between the metals and viola!
          Let me rephrase that. If I were having the same problems you are having, and I have, I would do the above, which I have. Not telling you to in case there are problems.
          #2 .....Cheesehead
          #3 '91 White - Donor Car
          #4 .....Montana Project
          SOLD----Levistiva for $1500
          Bought her back for $450
            problems? what problems?
              I soaked mine in a product called "Release-all" for about 10 or 15 minutes and that freed them up. Once that was done I worked some brake lube into the joint and then reinstalled them. Haven't had a problem since.
              Ian
                Hmmmm, mine looked ok. I hope I don't have problems with them. Would that thing getting stuck cause my front shoe on the pass side to be all worn down while the others look fine?
                  doe anyone know are festiva and aspire ones the same?
                    I believe festiva and aspire ones are different since they are different size brakes. Also I called FMS and they said they have the left ones in stock right now and should get the right ones sometime next month. They are $40/piece.
                    The Festiva Store
