I have a trailer and I just want to haul festivas.Any one ever build a reliable set out of 2x's ? I want about 4-5ft.Any pics ??
Wooden ramps hold Festiva ?
I dont know if I would trust 2x4s to hold such precious cargo
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
If your just building ramps then i would imagine 2x4's should work, but as the trailer deck, then i'd go with your idea of using 2x6's with 2x4 bracing
Just as a cheap "ramp" to get on the trailer.I have to tow about 20-22 cars about 45 miles to my town.Getting tired of going out in bfe every week to pull parts,so,I want to bring them home,take all the good parts off and scrap the rusty ones.
I used wood ramps when I picked up and aspire...they were about 5 foot long....had no issues with it."FLTG4LIFE" @FINALLEVEL , "PBH"
but did you use them for repeated use? I'm sure it would work once or twice but I can see the car half way up and the board crackingOriginally posted by GenevaDirt View PostI used wood ramps when I picked up and aspire...they were about 5 foot long....had no issues with it.
92 GL - parts car
i would use something like this:
The black parts would be 2x4s with the 4" being depth and the yellow bits would be a piece of 3/4" plywood that would be the part the tire touched. This would be an upside-down view.-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
Probably, it's a Festiva. Wood has pretty good tensile strength as long as it isn't really old or something like that.
(<-- needs to stop over engineering everything)-Caleb
yes....they barely flexed, and the Aspire is heavier then the Festy so I would not hesitate to use them for that purpose. Unless they are old and cracked or something.Originally posted by Festiva_tunner View Postbut did you use them for repeated use? I'm sure it would work once or twice but I can see the car half way up and the board cracking"FLTG4LIFE" @FINALLEVEL , "PBH"
here's how i'd do this ramp setup with 2x4's.. orient them with the 2 (1.5" actual) down and 4 (3.5" acutal) vertical... a 2x4 is much stronger that way, then just nail 4 to 5 2x4's together every 1 foot or so..... this would be able to hold a festiva easily.
-Aspire brake swap COMPLETE!
