Festiva down!
    The aspire swap uses the cotter pin
      well crap John, should have seen that one comming... but it felt fine when we adjusted it.
      No, it was fine when he left.
      As a matter of fact Tunner readjusted it before he left Sunday.
      Outer bearing fused itself to the spindle.
      Brought a spindle with me, But couldn't find the crush nuts.
      Turns out the spindle was the left hand threaded one and must have been swapped before with a passenger side one.
      I never even considered that the spindle might not be the correct one.
      Couldn't have used it anyway, as we couldn't get the last nut off the spindle backing plate, due to the lower damper bolt.
      And we all know what problems those are.
      So reused the damaged spindle, with Tunner using files, sandpaper and emery clothe to smooth-out the imperfections.
      Swapped in newly packed bearings and began the journey back.
      Stopped a few times to check the wheel for play and noted a high temp condition which later, 30 miles or so, went away.
      On a good note Tunner and I did find that Advanced Auto had 2 LH crush nuts, not the one we needed but we bought them anyway.
      A little disappointed I didn't see a better response.
      I wasn't able to get there till 3pm yesterday.
      I would have thought we would have had someone closer that though they may not have had parts could have lent a hand.
        John, you know I'd have come out with full rescue gear if he was closer.
        Jim DeAngelis
        kittens give Morbo gas!!
          Status Report
          Checked the bearing the bearing before I left this AM for work and all seemed fine - Checked again once ariving at work and again bearing was fine.
          I appreciate John comming out to assist and the driving to just about every parts store in the 20 mi radius to find a nut -
          To clarify it was the drivers side rear that went out and like John said the inner cage of the outer bearing fused itself to the spindle shaft - luckily we were able to use a nut splitter to get it of and then about 40 min of filing and sanding to return the spindle to a usable condition.
          Thanks to Arty and Jim for the original assistance and to Jim for the Q&A
          92 GL - parts car
          97 aspire - parts car
          87 323 DX - daily driver
            Jim, I have no doubt of that whatsoever, I was thinking of some members within an hour or so of Cincinnati, OH.
            I just can't believe we have no members in that area.
            I'd have made the trip anyway, but then Tunner wouldn't have had to wait for me to get there and he may have been able to effect a repair earlier.
            Just another reason for when members are making long treks that they let us know so that some of us can mount a rescue mission if need be!
              I'd feel better if you replaced the spacer/washer with the "tang" that fits into the "keyway" in the spindle and got a new RH threaded nut.
              I can hit the JY if you can't get the washer.
              Let me know.
                Let me know.
                Yeah I will be getting a new nut for sure - the washer will be replaced as well - if you find one in the yard that is in good shape save it in case I cant get a new one.
                92 GL - parts car
                  I don't believe you'll be able to obtain a new keyed washer. Used is you best bet. they don't usually wear out, unless as a result of catastophic failure.
                  Jim DeAngelis
                  • #24
                    Or near catastrophic faliure as in my case - the washer took on some wear due to me limping it off the highway down the exit ramp and across the street to the gas station - only to be told if I leave my car there overnight it would be towed in the morning if I didnt move it - even if I was with the car - so it was put back together and limped down the street to a hotel parking lot - meaning alot of stress on that washer with the outter bearing being gone
                    92 GL - parts car
                    • #25
                      So, if I understood this correctly you had a right side spindle, on the left side of the car?
                      Never seen that done before..... hope I don't....
                      Just when you thought you had seen it all.....
                      I had to chisel off the nuts, and replace them. Not something I would like to do as emergency repairs in a parking lot. Bad enough to do it at the shop as it is time consuming working around the cage work of the swing arm. Those, and the bottom strut bolt.......
                      I am glad everything worked out, and you are home. I was close enough to the shop when the right side welded on Rasta, but it rode on the washer like yours for a few miles. Yes, a few miles...... It was nerve racking!
                      Have owned 9 so far
                      • #26
                        I was looking on Rock Auto today, and they have the washers available as a pack of 5 for the rear hubs for 4.09 ea. Dorman p/n 618020. If you order much more, you can also use discount code 21566431800861 in the" how did you hear about us "at checkout for a 5% discount if you didn't find the washers local.
                        HTH
                        Michael
                        Have owned 9 so far
                        • #27
                          I found the parts local - Johns spare axle had a right side spindle on the left side so when he brought it it was the wrong one
                          92 GL - parts car
                          • #28
                            You started drilling the spindles after I lost the rear wheel on the white Festiva on my way back from your place didn't you Dean?:-) I'm glad I was driving the car for Htchbck(Joseph). Needless to say, it's not a short trip from Raleigh, NC to Atlanta, GA!
                            90 Festiva with Brand new B3, 5spd
                            92 B6 Festiva, 5spd
                            • #29
                              When you get there, tell Joseph to PM me; I have his Aspire grill; paid $10 for it.
                              • #30
                                Need me to transport it to FMIII?
