Originally posted by Evil D
my official mpg test.
Originally posted by TominMO View PostFor some reason, MPG seems to go down when you put a turboed B6 in place of the stock motor.
Under real world conditions (read me driving whatever speed I happen to be going:-D) My 89 carby 4 speed seems to average somewhere between 42 and 45 mpgs. Meant to chart mileage to OSX, but too lazy to actually write down mileage at fill ups.
1989 L - 247K miles Slick
Ok so someone tell me what i'm doing wrong...i've just done a full tune up...what more can i do? If there are people getting 40+mpg with the same car as me (the above post being my car exactly... an '89 4 speed carby) then why am i getting 30ish at best?
Originally posted by Evil D View PostIf there are people getting 40+mpg with the same car as me (the above post being my car exactly... an '89 4 speed carby) then why am i getting 30ish at best?
Long idling (going nowhere)?
Wheel squealing starts from stop signs and stoplights.
High speed driving style?
Carry excessive useless weight in the car?
Low tire pressure?
Lots of short drives?
Larger than OEM tires makes ODO read short of actual miles, thus calculations of MPG are low.
How many tanks of fuel is this 30ish figure based on?'93 Blue 5spd 230K(down for clutch and overall maintanence)
^^ In all honesty, mine is not stock carby. Mine is sans all of the vac lines/sensors/all that emissions stuff. Don't know if that should help or hurt my fuel economy, but I'm guessing it helps. My 88 carby only averaged between 35-38. So I'm guess not having all that stuff hooked up must help.
I drive 90-100 miles a day, 5 days a week, almost all freeway.
My 88 B3 5 spd would get an easy 45+mpg regularly, no special driving- just go with the flow. Stick at 55-60mph and get 55+mpg.
The B3 died and I put a B6 in its place, carbed and now can't get past 31mpg no matter what I try.
I picked up a 91L B3 injected (of course) 5 spd and so far I have managed a best of 57mpg.
Honestly if I can see 40-45mpg I am a very happy camper.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
Originally posted by Oren09 View PostI've also been experimenting with Premium gas. I know the higher octane won't really help the fuel mileage, but at the Exxon station here, the Premium doesn't contain ethanol. I seem to have gained a bit of mileage, but nothing significant. I'm about to switch back to regular (10% ethanol) and see if the mileage drops.
Gas logs: http://www.fuelly.com/driver/oren09/festiva
Originally posted by neanderpaul View PostI've seen several carbys that got around 30. Every single one was really quick for a stock festiva.In love with a MadScientist!:thumbright:
Low tire pressure?
Originally posted by batstiva View Post^^ In all honesty, mine is not stock carby. Mine is sans all of the vac lines/sensors/all that emissions stuff. Don't know if that should help or hurt my fuel economy, but I'm guessing it helps. My 88 carby only averaged between 35-38. So I'm guess not having all that stuff hooked up must help.
Originally posted by econoaddict View PostI drive 90-100 miles a day, 5 days a week, almost all freeway.
Honestly if I can see 40-45mpg I am a very happy camper.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostCarbed B6? So you put the B3 carby manifold on the B6? Try switching to a Weber or Holley/Weber. You should get more power and more mileage too.
I know a weber would be a huge differemce in power, mileage and runability.
The B6 being FI has NO provision for the egr valve so all the egr/feedback stuff is now just along for the ride plugging holes.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
my yaris went from 39.7 mpg average down to 31-33mpg once the ethanol e10 was mandated here. there is only one place i know of and it is in springfield oregon that sells straight non corn gas and it is 80 cents more. but, it is for exemptt vehicles. my charger is exempt but the festy is nowhere close. the charger runs so much better on non e10 gas. the yaris hates it too. i have found (cue boos) that the shell with nitrogen(a joke?) premium got me in the 35 to 37 again in the yaris. i am hoping i can find a non corn based station on the dumball rally. we're leaving portland-ish oregon and going to ....orofino idaho, then to bozeman, then to jackson hole.
any suggestions of gas or food?
thanks!!
mark
Try running 40 psi in the tires (or whatever the max sidewall is) instead of what the door sticker says... and coast coast COAST. The more you use your brakes the more momentum you waste.91GL BP/F3A with boost
