Will antifreeze corrode pvc pipe?
    Originally posted by perucho View Post
    PVC has poor compatibility with propylene glycol. What do you want to use pvc for anyway?
    Originally posted by NovaSS View Post
    chemical compatabilty page link ........
    To use .. select the two materials from first two boxes, then in third option box select "all" and hit "submit"
    according to this it stands up very well
    Ethylene glycol compatibility is A (excellent) but propylene glycol is C (fair). Antifreeze as a chemical is a bit vague.
    All of the above is true!
    And unfortunately, it is more and more difficult to determine if an antifreeze is ethylene glycol or propylene glycol.
    You need to have an MSDS, because color is no longer an indication of composition.
    "corrode" should not be used in this context.
    Metals corrode via and oxidation/reduction process.
    Plastics have chemical compatibility issues along with chemical and environmental conditions which can lead to material failure.
      Stainless is the key!-where I work it's used in multiple applications and in contact with volitile substances.
      91' Festiva GL <AKA> "Little Boy Blue"
        festivBS, there you go Mctiva will send you some "cheap" stainless.
        A materials volatility has nothing to so with it being corrosive.
          I think i'm just gonna use some copper tubing since i can go down the road to the hardware store and get it. As usual i learned alot from all you smarta$$es -Thanks!
          -93' Festiva L (B6T swap in progress)
          -92' XR2 Capri (Parts car)
