Junkyard Festy
    Originally posted by Oren09 View Post
    Ok. I bought the Festiva today (thanks Dad and my truck's broken axle and driveshaft...)
    I had to drive it 15 miles to get home. It did ok. Would die as soon as I let off the clutch and the shift points were all over the place. No power in second or 4th gear.
    I've taken off the intake plastic and am waiting for the metal parts to cool right now. I have work at 5 though.
    I no longer have my Haynes manual- it went when I sold my other Festiva.
    How do I remove the throttle body/intake to take off the valve cover?
    I will post pictures of the whole car sometime soon. Give me a week or so to get it running.
    It is a 1993 Festiva L, red. Dealership plaque on back from Carrolton, TX, about an hour from where I am now. 58,000 miles.
    Well congradulations! A nice rustfree Festiva! We can help you get it going.
    91 Festiva GL "Scrat"
    82 Honda Goldwing GL1100i
    85 BMW 535is "Brunhild"
      Yank the head off the aspire, have it refreshed and throw it on. Its superior to the festy head anyway.
      91GL BP/F3A with boost
        If your valve cover won't come right off, turn the engine over briefly and check to see if it will come off. The valve rockers need to move a bit and your cover will then clear the throttle body and come right off.
        Don't be like me and spend a half hour filing on the valve cover and throttle body bottom.
          Thanks you two!
          I'll try to remove it when I get off work tonight
          I just cleaned the interior and windows and its near perfect! Nothing missing or broken, few stains, small driver's seat tear.
          ~Austin
          Red 88 L (Ocho)
            Does it have any oil in it? Just a thought.
              Nothing shows on the stick....
              How much does a Festiva take?
              ~Austin
              Red 88 L (Ocho)
                3.2 QUARTS as far as i know
                  Thanks. I'm going to pull the valve cover anyway though because the car smokes BAD and there was oil coming out of the throttle body.
                  ~Austin
                  Red 88 L (Ocho)
                  • #24
                    Dude its easy to remove the valve cover you will need to remove a bolt that is located to your right side (its like next to the thermostat) move that bolt will give your valve cover more room to wiggle around.
                    • #25
                      I got the valve cover off. Wasn't that difficult.
                      There's nothing obviously wrong, but I don't know that much about engine internals.
                      Pictures are here:
                      Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                      I removed the spark plugs to make the engine easier to turn by hand. Each plug had fresh liquid oil on it. Also, as I turned the engine, smoke would come out of the spark plug holes and the engine was ambient temp- hadn't been run in well over 6 hours.
                      Is it possible the timing belt jumped teeth or that the timing is just off?
                      The rockers all appeared to move as they should. I was turning the crank very slow though, so I'm not really sure.
                      ~Austin
                      Red 88 L (Ocho)
                      • #26
                        can you describe the color of the oil? The engine looks fairly clean, it may very well just need a new head gasket. If so that is not a bad deal you got there.
                        • #27
                          The oil doesn't look bad, doesn't look like there's coolant in it.
                          The coolant kinda has a rainbowy shine to it, but still looks green.
                          My dad followed me yesterday and said the smoke looked more white and didn't have a super strong oil smell- "like it was all oil."
                          I think the head gasket is blown, but would that alone cause no idle, and rough, noisy running? The car had no power yesterday, especially in 2nd or 4th gears and topped out at 55, but would slowly loose speed down to 30 at one point. It never overheated but the temp gauge did climb up to about 3/4 a few times.
                          ~Austin
                          Red 88 L (Ocho)
                          • #28
                            Checked air filter? Make sure its clean just a suggestion.
                            • #29
                              Id recommend a motor swap any way. Im having nothing but trouble with the stock 1.3L. Do a b8. Swap and have some fun
                              • #30
                                I don't have the knowledge, equipment, or time for a full engine swap.
                                Going to check the air filter now.
                                ~Austin
                                Red 88 L (Ocho)
