oil changes
  • oil changes
    Hey, i'm changing my oil every 2k, been using the fram xtragard (9 bucks) Changing that often, can i use the cheaper filter( 4 bucks) without worries? Also, using valvoline 5/30, decent oil?
    I think you should wait 3k before changing. Even at 3k my oil still looks close to new just my .02
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
      I usually change every 5k (km) just oil, oil filter every 10k then flush every 15k
      using high quality stuff.
      93 Ford Festiva WA (project car)
      98 Ford Festiva WF (aspire)(parts car)
      98 "Gloria" Toyota Corolla AE101 (daily driver)
        The Mazda engines are so well built, that if you do oil changes every quarter, using good (not best) quality oil and filters, you will be fine. Just know what you are doing and do it on schedule.
        If you go the high performance route, with rebuilt engine, etc., then maybe crank up your quality and servicing. Not necessary on stock engines.
        Karl
          Your real concern should be the Fram filter. Cut one open and look at the shoddy construction. I only use Wix, Motorcraft, Napa Gold or Silver, Purolator or AC/Delco. The Delco and Ford filters are made by Purolator.
            I go with a top filter like the Wix, or Purolator PL series filters. Any oil is good enough IMO, but I am now using the Castrol High Mileage, 5W30 for winter and 10W30 for summer.
              I recall reading other guys complain about Fram filters in the past, so I've generally avoided them. I do use Bosch, though, sometimes.
              Karl
                The Fram and cheap filters are just cardboard shoved into a tin can. Wix and Napa are the route to go.
                1991 Smoketiva - 306k
                1997 Jeep Cherokee - 4.6L Stroker
                2004 Sebring
                  X2...................actually, I think the "top-of-the-line" Frams are built much better than their standard line & get pretty good reviews. Otherwise, they're crap.
                    What do you guys think of the Purolator Pure One filters? Advance is running a 20 percent off sale now and the Pure One Festiva filters are down to $5.00 each. With the discount they are $4.00 each!
                    I'm about to make an order, including five Pure One Oil Filters (for Festiva) to go with some more wheel paint.
                    Pretty good deal, or are the Pure Ones just so-so? I've usually run Bosch, but I also bought a couple NAPA Gold and one Wix. (I prefer the Festiva size instead of the 323 spec, since they're bigger.)
                    Karl
