Hey, i'm changing my oil every 2k, been using the fram xtragard (9 bucks) Changing that often, can i use the cheaper filter( 4 bucks) without worries? Also, using valvoline 5/30, decent oil?
oil changes
I think you should wait 3k before changing. Even at 3k my oil still looks close to new just my .021992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
The Mazda engines are so well built, that if you do oil changes every quarter, using good (not best) quality oil and filters, you will be fine. Just know what you are doing and do it on schedule.
If you go the high performance route, with rebuilt engine, etc., then maybe crank up your quality and servicing. Not necessary on stock engines.
Your real concern should be the Fram filter. Cut one open and look at the shoddy construction. I only use Wix, Motorcraft, Napa Gold or Silver, Purolator or AC/Delco. The Delco and Ford filters are made by Purolator.1963 Fairlane - future NSS drag car
I go with a top filter like the Wix, or Purolator PL series filters. Any oil is good enough IMO, but I am now using the Castrol High Mileage, 5W30 for winter and 10W30 for summer.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I recall reading other guys complain about Fram filters in the past, so I've generally avoided them. I do use Bosch, though, sometimes.
X2...................actually, I think the "top-of-the-line" Frams are built much better than their standard line & get pretty good reviews. Otherwise, they're crap.Originally posted by Larry Hampton View PostYour real concern should be the Fram filter. Cut one open and look at the shoddy construction. I only use Wix, Motorcraft, Napa Gold or Silver, Purolator or AC/Delco. The Delco and Ford filters are made by Purolator.Last edited by blkfordsedan; 06-06-2011, 06:46 AM.Brian
What do you guys think of the Purolator Pure One filters? Advance is running a 20 percent off sale now and the Pure One Festiva filters are down to $5.00 each. With the discount they are $4.00 each!
I'm about to make an order, including five Pure One Oil Filters (for Festiva) to go with some more wheel paint.
Pretty good deal, or are the Pure Ones just so-so? I've usually run Bosch, but I also bought a couple NAPA Gold and one Wix. (I prefer the Festiva size instead of the 323 spec, since they're bigger.)
KarlLast edited by Safety Guy; 07-02-2011, 04:56 PM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
