Removing shift knob
  • Removing shift knob
    So I figured all they needed was to be Screwed off, this is not the case unless mine is stuck.
    HELP!
    Previous owner of ZEFstiva
    Yep yours is stuck. It should just screw right off. Grab it with both hands and give it a death grip. Twist as hard as you possibly can. It'll come off.
    89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
    My site: 20tessa.sytes.net
      Righty tighty lefty loosy ha ha jk
      if u cant get it to turn and dont mind a coupke dings in the knob, take a channel locks or any bigger tyle pliars and try that. keep in mind leverage is your friend.
      :cry_smile: RIP. 91 Ford festiva BP swap
      1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
        you know those sockets that remove stripped nut heats. I'd guess a 50mm size and use your 4 foor breaker bar. That don't work, burn it off. fire! fire!
        Seriously, I had one do the same thing. I used a towel and some channellocks like mckabe said.
        -Bryant
          Sawzall.
            Step 1-Go to Gym
            Step 2-Pump Iron
            Step 3-Try Again
            Step 4-(Optional)-Pick up chicks at Gym in your sweet Festiva!
            That is what I would recommend.
            -Donny
            -1992 Festiva GL
            B6D/E-series.
            -1991 GL
            BP/Broken E-Series. Working on G transmission.
            -2011 Mazdaspeed3
              ^i second this
              1991 blue L, 5 speed.
              1988 red L-plus-all stock.
                There is NO problem that can't be rectified with the use of high explosives!!!:hal
                '93 Green L - ' Tiva
                  Dumb question but you never know... Have you removed the boot around the shifter? Those can hold them down pretty well!
                  My Musica! Click me!
                    I mhad to use a pipe wrench to remove mine the first time!!!
                    Chuck
                    91 GL -Ol' Rusty
                    93 GL - Lil Red
                    91 L - Tweetystiva
                      I think the point is thay do get tight sometimes but they will come off. lmao
                      -Bryant
                        Righty tighty lefty loosey
                        Ford Fester
                          Mine spins as I drive, 1/2 the threads are stripped, lol
                          Owner of:
                          1991 Red Festiva L, 5 speed (Swagger Wagon)
                          In progress:
                          BP+G25MR swap, Kia rio axles hopefully.
                            Where are you Chad?
                            -Bryant
                              Maybe it was put on with Loc-Tite Red.
