Ok i have intentions on doing my first motor swap for my festiva I am going to put a kawasaki is-750 in its driveshaft driven now this is just a thought could I make this work threw my tranny just wondering like as an active 10 speed? I already figured mounts and relocation of battery and what not but is the possible?????
750cc festiva questions
Yes and sorry for the missing info. I have a hard time typing it as I am thinkin I skip words alotOriginally posted by 2xclutchin View PostSo 750>750 tranny>Festiva tranny, like that? Just trying to clear that up.89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
Yes, it's possible. No, it wouldn't be a benefit at all, because it wouldn't be 10 synchronous gears, it would be 25 ranges. (Assuming the other engine has a 5 speed transmission).
Your best bet would be to run the stock transmission into a hard mounted diff and split that into the wheels. Use a subie rear diff, that'd be easy enough.
I guess if one planned on towing with it, it would be good, but empty you would skip 3/4 of your gears. We have a '63 Freightliner with two 4's, empty you don't even need the 1st gear in the main tranny. Although going through multiple gears in reverse is always fun
MikeMike Holmgren
Thief Rvr Fls, MN
1989 Festiva L, carb. 4 spd.
"If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
I think I am just going to go with my original idea and make a solid chormoli axle for the rear and set a yamaha r1 over it and make the car rear wheel drive and pull stock motor and granny out and build it into a box and run vaccum breaks wont take to many mods I will do it89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
Cool! Chopping out the spare tire well and boxing out the rear takes a lot of ingenuity, but it'll make an absolutely awesome Festiva! Couple questions from me, because I love reading about motorcycle builds:Originally posted by newcomb View PostI think I am just going to go with my original idea and make a solid chormoli axle for the rear and set a yamaha r1 over it and make the car rear wheel drive and pull stock motor and granny out and build it into a box and run vaccum breaks wont take to many mods I will do it
1. What are your plans for motor lubrication and chain work?
2. Fuel cell mounted up front? What about the battery?
3. Radiator and cooling? Cabin heating in the winter?
4. Modifying the engine at all to improve TQ output?
5. Any changes to the front suspension to reflect weight distribution?
6. Are you going to run an electric reverse gear?
7. Any modification to wheel wells for tire width and grip?
8. What do you expect it to weigh in at when finished?
9. Megasquirt or what in terms of EMS?
10. What's your solution for electronics, alternator, and so on?1988 Chevy Sprint Turbo 997cc
Snowmobile engine??
has reverse
has turbo
has alternator
works well with solid axle
EMS aftermarket well established
use snowmobile battery.
Use snowmobile handle bars and brake less weight
Put the skis and track back on for winter use
-Plans for the motor yamaha r1Originally posted by Aaronbrook37 View PostCool! Chopping out the spare tire well and boxing out the rear takes a lot of ingenuity, but it'll make an absolutely awesome Festiva! Couple questions from me, because I love reading about motorcycle builds:
5. Any changes to the front suspension to reflect weight distribution?p
-Yes fuel cell up front where the b3 was
-Battery I plan on placing in a fabbed box near the hatch for easy access
-Radiator I plan on using the r1 radiator as for heat ill have to figure as I go but that won't be hard probably tap into the stock r1 radiator
-As for torque i plan on putting a set of cams and intake work
-As for front suspension I lowered it and adding some homemade lead weights to help difference
-No reverse that's only down fall "Flintstone" lol
-Tubbing and adding a set of 12" wide slicks
-Weight I am goin to shoot for same at first then lightening begins
-Electronics I plan on running the r1 alternator and my current battery smallest possible for b3 and go from there I will have a 10 gallon fuel cell I am going to use the wireharness and gauges for r189 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
Look up 650cc Geo Metro on Google. It's been done. Hopefully that will work out any kinks you might have.Last edited by DriverOne; 01-08-2012, 12:32 AM.In love with a MadScientist!:thumbright:
I hope you don't take offense to this and i'm not trying to sound like an ahole, if you can't get the carb right in your car to get better mpg, you'll have a heck of a time with a mc engine swap. I'd like to see it done, but is it realistic?Rick
1993 Ford Festiva
1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
2000 Ford E350
Actually I've done figured it out thank-you and it WILL be doneOriginally posted by Eaglefreek View PostI hope you don't take offense to this and i'm not trying to sound like an ahole, if you can't get the carb right in your car to get better mpg, you'll have a heck of a time with a mc engine swap. I'd like to see it done, but is it realistic?89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
