Mine has 343,xxx miles and still ticking. Is this normal/good/great/exceptional for 93 5spd's?
How many miles on your original Motor?
Tags: None
Not sure mine only has 98000 so I'm curious bout this one as well1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.
i'd say that's between good and great. i regularly see them in the high 200s... break 500 and THAT would put you at exceptional.Trees aren't kind to me...
Wow. 500k would be so sweet. I'm guessing that would take me about 6-7 more years to hit on the low side lol. My goal at this point is 400k with the original engine.
Landmark lifespans for stock econoboxes I think. Dollar for dollar best car ever made?
@ fm5 my 88lx had 429k still getting 37mpg on the hwy & original clutch, it did sound like a diesel though
& i entered the high mileage contest & got 2nd place, the festy that won had over 600k!!!! was that scitzz that won that?
Never Hire a Boy to do a Man's Job!!
Certainly the Japs have redefined durability and lifespan for engines already beginning in the 1970s through closer manufacturing tolerances and better materials. Caused everyone else to pull up their socks (or in the case of utility 2 and 4 strokes; caused Johnson, Pioneer, Lawn Boy, Tecumseh etc to close up shop). Used to be in the 50s and 60s a Detroit or UK auto engine with 100,000 miles was worn out.Originally posted by mikeyjd View PostLandmark lifespans for stock econoboxes I think. Dollar for dollar best car ever made?
The saving grace of Mazda B-series (I think) is that they are non-interference engines meaning your typical accidental broken belt scenario (which has plagued Kia's copies) hasn't spelled an end to the motor and makes owners are little more likely to try to keep them going.
214,204 on the Auto, beaten to death atleast 50k before me, and 35k by me personally. Floored at all times, 5k RPM up most hills haha.
Doesn't leak very much oil.. forgot to change oil for 8.5k miles once and it only lost half a quart! :p
-JoeWhite '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
I have 3 Festys and all show somewhere around 300K km (180K miles) on the clock. Only one has ever required engine work (a burnt valve which is why I got that one cheap ($50) 6 years ago) in all 9 years that I've been running these things. The best one, which was fastidiously/religiously maintained right from new burns no oil between changes nor does the colour even darken appreciably.
40 years ago I drove a dozen different Austin Minis. To go 10,000 miles without some sort of major overhaul (bearings, valves, rings, pump, lifters, gaskets) was considered a miracle. An OHV 1.3 litre (the super high performance "S") of the time red-lined at 6500 and put out 75 hp, but was worn out (as in: thoroughly bagged) at 50,000 miles whereas our 1.3 'housewife's' engines (that 'go' almost as good) are widely known to go 1/4 million miles between service.
This time around I think we do have to thank someone (Japanese automotive engineers as a catalyst?) for allowing us to actually experience, and take for granted, "progress".
