alright, well, the motor works great, the compressor works but it takes forever to build up pressure. The compressor is supposed to be rated for 19 cfm@1750 rpm, so there's just no way it's doing what it should. I can hear air escaping through the compressor, and when I take the oil fill plug out the crankcase is pressureized.
I thought maybe the rings were shot, but I popped the head off one side (the one that sounds like the leak is comming from) and I can't see anything wrong. I dropped oil into the cylinder last night and it's still as full now as it was then. There was a bit of gunk buildup all over but I'm slowly cleaning all that off then bolting it back together soon.
Could it be the valve thing on the top? Here's a link to the online pdf for it.. http://xpedio.carrier.com/idc/groups.../5f,h-23si.pdf
maybe the springs and things inside the heads just need cleaned really good? That's what I'm going to do anyway, rebuild the top ends and reuse all the old parts since I am having trouble finding any new parts.
