rear turbo questions
  • rear turbo questions
    What are some of the disadvantages of a rear turbo? What does the extra length do to the intake if anything? Anything else that may make me not do it?
    Now what are the advantages?
    -Bryant
    It sounds cool
    91GL BP/F3A with boost
      Cons...
      1. Ground clearance, although mine does not scrap very often, but is lowered.
      2. Driving thru creeks, and rivers. It just doesn't work, ask me how I know..lol
      3. Dealing with haters (easiest way is a test ride)
      4. We'll that's about all I see, I'm sure others have their two cents
      Pros....
      1. Turbo, that's all to be said about that
      2. No intercooler, so no hacking up a front bumper, can be made very hidden, aka Barbie car
      3. Being different
      4. Sounds way cool
      5. Faster than bhazard
      6. Turbo stays cool, which extends life of turbo.
      7. Oil lines add capacity, and cooling
      I can go on and on
      -Greg
      Redneck Engineer
      FOTY - '09
        There will be more turbo lag when you put your foot in to the floor.
        Since there will be more air in the extra length of tube.
        It will have to compress all of that air before the boost reaches your engine.
        People usually mount under the hood because its closer to the intake and less turbo lag
        Since it's at the rear there will be less heat as energy to propel the turbo.
        But it may also deliver a cooler intake charge as a result as well as the extra intake piping
        To help "wick" extra heat away before the intercooler.
        Giving denser cooler air.
          No intercooler needed.
            When my B6 was rear-turboed, I never experienced any lag that I could notice. Depends somewhat on the diameter of pipe you are running back to the intake.
              Lol, you guys crack me up. I like #5.
              -Bryant
                i Have rode in euro and i don't feel any lag when greg gets on it.
                www.facebook.com/rhodestiva ;
                rhodestiva@gmail.com ;
                '92 Festiva L M/T
                '93 Festiva GL A/T
                  No need for moding ir buying a turbo header
                  -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
                  -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
                    People can say lag, but do they or have they had a rear turbo car?.same concept as a garden hose. When you turn it on the whole hose, water, air, or a mixture there of, is pressurized almost instantly.
                    Has anyone ever measured the overall length of the piping under the hood including intercooler. I know the pipe under my car is 7.5 feet long. Probably another two feet at each end, not really that much different
                    -Greg
                    Redneck Engineer
                    FOTY - '09
                      TOO FUNNY
                      Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
                        no cat & no muffler needed! when your racing for $$$ & you open the hood youve got em!!! ask festevil3:whip2:
                        Never Hire a Boy to do a Man's Job!!
                          And i could be totally wrong but Doesn't the dia of the pipe run back and forth play into that equation?
                            I love my rear turbo car, hands down my favorite one! They can be the ultimate sleeper, most NA Honda guys think you just have a weird cold air intake. After the race is over they know something up and don't wanna' give me there money, but they never ask me if it is boosted.
                              Brake boost it when racing, and I promise there is no lag!! ....a little trick Eurotiva taught me
