Front turbo oiling consists of approx 1.5' of supply line and about 1.5' of return hose.
Rear turbo oiling system consists of car length supply line and car length return, which isn't a big deal, but you also need a pump to push it back and a turbo timer to keep the pump running to scavenge as much oil as possible from the lines to keep oil from from sitting in the bearing housing and coking which will kill the bearings over time.
A turbo is more efficient when its closer to the engine. Heat = energy (thermodynamics!). Combustion gasses start cooling and contracting as they leave the cylinder and a section of pipe doesn't transfer pressure instantaneously since a gas compresses, unlike water. If its just for fun like 95% of us here slap a turbo wherever you want and enjoy it. Either way will put a smile on your face for sure. When you see high hp turbo builds you typically see equal-length tubular manifolds feeding divided inlet turbines which add up to more efficient flow and faster spool.
Do it!!!! Forget the haters, just do it! If you need help I'll do what I can to roll up there and help out, then we can RT one of my cars lol, after things get ironed out on your car first of course :p
Dang it Matt, why you gotta get all technical. Your right, and why didn't you beat bhaz while at Fm7?
All I know is... turbo >na
Cause I lost a lot of motivation and I'm tired of trying to improve a POS car. For example I can't even drop my cross member because I can't even get one of the front bolts out without hacking it to bits. I literally just beat on it half hoping it will blow up or the trans will finally let go so I have an excuse to part it or let it sit for another year but it just keeps going...
What I really should be doing is be working on building an engine for the next car. 10 or 11:1 forged BP with fully ported head big valves all balanced, decent ball bearing turbo blah blah. 250-300hp running through my built automatic on megasquirt in a CLEAN body should make me happy.
91GL BP/F3A with boost
You won't be happy, with an auto, but it should be fast.
Rocketman, I use a gear type carburetor fuel pump from summit. It's been on mine 50k, with no issues. I've read so much online about people having pump problems, even sts says theirs is only good for about 12k
And I have considered a stand alone oil supply, but it needs the pressure to "float" the shaft. High pressure pumps seem to be more expensive
Yes Matt. It's mine now. Still sitting in garage waiting to be tore down and parts cleaned. Pretty much a weekend thing only. I will try and let you know a couple days ahead when I might have time to work in the garage. LOL
1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
