i got no door buzzer at all... the dome light does work but does not reflect on the door though (only works if turned on manually)... i don't know if the buzzer has anything to do with the light ? i kinda like not having a buzzer but if you need it to fix the dome light then how do you get it to work
no door buzzer / dome light
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
Have you checked the little door nipples? The switches that pop open/push closed when you open and close the door? Power belts working (if they're power)?White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
I'm with Spike...check those door jam switches. I have several if yours is bad.
power belts work great, when i open and close the door the belt movesOriginally posted by Spike View PostHave you checked the little door nipples? The switches that pop open/push closed when you open and close the door? Power belts working (if they're power)?Last edited by old yellow; 10-21-2013, 12:41 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Door Jam switches hardly ever go bad. The problem is corrosion on them. Disconnect the battery, unscrew the switches from the jam and pull them out. You will see that they are a simple grounding switch. Clean the corrosion from the contact points and reinstall. Also check the position of the interior light switch. Should be in the CENTER to work with the door sw. If it's pointed at the drivers door it will be on all the time ( I believe ) Pointed at the passenger door, the light will not come on all. Hope this helps.Last edited by hotfordcat; 10-21-2013, 01:06 PM.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
I think the door buzzer is only in the Tach clusters..
well if i point the light switch towrds the driver's door the light comes on... all other positions the light is off all the timeDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Originally posted by 1chrisapple View Postno the tach clusters have a headlight buzzer when the key is off and the lights are on.
there should be a buzzer in there when door is open and dome light should come on but I bet its the door jam push buttons.
Yuck why would you want it screaming at you whenever you opened the door.
He's asking a lot of questions about his new car. It would be faster to just ship Arty to him in a box (with airholes) to straighten everything out.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
hey the only way to learn is to ask questions as my one teacher said...Last edited by old yellow; 10-21-2013, 03:08 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
lol! ya i guessOriginally posted by TominMO View PostHe's asking a lot of questions about his new car. It would be faster to just ship Arty to him in a box (with airholes) to straighten everything out.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
