What is all this B3 B6 stuff?
  • What is all this B3 B6 stuff?
    I see it in posts all the time but I can't figure out what it stands for?
    B3 = Mazda B series 1.3, B6 = Mazda B series 1.6
      The Festiva and Aspire have a B3 engine. The B6 is from a number of different cars and is a common engine swap to upgrade the power.
      -Rafe-
      Things I have for sale.
      Random Festiva Parts
        I personaly believe that nobody should waste their dime rebuilding a B3.
        There are a lot of B6 engines available for rebuild and you will definitely have a smile on your face. I got mine from a Mazda 323.
          Agree, total waste of time. Oh wait.....
            and so you know, the B6 is a bored out B3, same block, bigger displacement, and a little more power, also is a DIRECT swap since it is the same block!
            Dan
              I wouldn't rebuild either to many good ones found for cheap
                I wouldn't build a B3 unless it's for a gas mileage motor project which I am doing.
                Jerry
                Team Lightning
                Owner of Team Lightning
                93 L Lightning. BP
                  Here we go again with the "do not build a b3" stuff again. The original question was what is b3 and b6?
                  -Bryant
                    would a b6 bolt to the stock festiva transmisiion?
                    89 festiva. No motor. Ready for B6 or B8-ME
                      Yes it will bolt to a stock transmission. Use the clutch, flywheel and starter for the stock transmission with the B6.
                      Jerry
                      Team Lightning
                      93 L Lightning. BP
                        the B designates the "family" of the engine. that is to say that the basic architecture/layout of the block is very similar within that family. all Bs are inline 4cyl. mazda has other families of engines such as G, MZR, K, etc. the number after the B is a ballpark value for the displacement in cc. there are B1, B3, B5, B6, B8, BP, BPD, BPT displacements and configurations in this B family.
                            Waste of dime$$$$$$. Money. Lettuce. Penionzie. Hroshi.
                            B6 is exactly the same size externally and the rebuild kits are more readily available.
                              tried to edit my post but the time limit was up. should read - B is a ballpark value for the displacement in THOUSANDS OF cc. but sometimes when you're going up a steep hill it does feel like 3cc.
