Engine Diagnostic Tool
  • Engine Diagnostic Tool
    What Engine Diagnostic Tool if any do you use on your Festy hmmmmmm.
    A hunch is creativity trying to tell you something.
    Let's see: eyes, ears, vacuum gauge, common sense, limited experience, manuals, flashlight, paper clip, eurotiva.....
      If you're just looking to run codes you can ground the single-pin connector at the drivers side rear of the engine compartment, turn on the key, and the check engine light will flash codes.
      Axlander9289, brother of ThisVelologist
      Festivas past:
      Aqua '92 Festiva L - Sold "Dale"
      White '89 Festiva L Plus - RIP "Dudley"
      White '93 Festiva GL - Sold to thisvelologist "Frito"
      Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
      Current Fleet:
      Aqua '93 Festiva L with Aspire brakes "Dale Jr."
      Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
      White '15 Ford Transit Connect
        Yes, I was looking for a particular code reader that might fit Festy very well. My guess is in view of the few replies here that perhaps NONE really exist.
        Thanks :sad11:
          What about those old Ford code readers you can still find at auto parts stores? I always wondered if those would work, but they would just do the same thing as grounding the STI plug. Except it just blinks the code with an led on the reader.
            Hence the paper clip.
              A good inductive amp meter and a long pricked test light sure help save some time.
              A cheap boroscope is fun.
              A cheap DVOM wired to anything while you drive. In this case .460 O2 volts is about
              Stoichiometric. Figure out fuel mix for power or mileage. Far superior to wide band
              sensors and computer systems of course.:wink:
              Information sources to learn exactly what you need to know.
                So that's what a "Boro" looks like. Ha ha, couldn't resist.
                I hate being Bi-Polar, it's awesome.
