What Engine Diagnostic Tool if any do you use on your Festy hmmmmmm.
Let's see: eyes, ears, vacuum gauge, common sense, limited experience, manuals, flashlight, paper clip, eurotiva.....Last edited by TominMO; 04-27-2015, 12:59 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If you're just looking to run codes you can ground the single-pin connector at the drivers side rear of the engine compartment, turn on the key, and the check engine light will flash codes.Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
Yes, I was looking for a particular code reader that might fit Festy very well. My guess is in view of the few replies here that perhaps NONE really exist.Originally posted by Axlander9289 View PostIf you're just looking to run codes you can ground the single-pin connector at the drivers side rear of the engine compartment, turn on the key, and the check engine light will flash codes.
Thanks :sad11:A hunch is creativity trying to tell you something.
What about those old Ford code readers you can still find at auto parts stores? I always wondered if those would work, but they would just do the same thing as grounding the STI plug. Except it just blinks the code with an led on the reader.Last edited by TorqueEffect; 04-28-2015, 04:37 PM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Hence the paper clip.Originally posted by Axlander9289 View PostIf you're just looking to run codes you can ground the single-pin connector at the drivers side rear of the engine compartment, turn on the key, and the check engine light will flash codes.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
A good inductive amp meter and a long pricked test light sure help save some time.
A cheap boroscope is fun.
A cheap DVOM wired to anything while you drive. In this case .460 O2 volts is about
Stoichiometric. Figure out fuel mix for power or mileage. Far superior to wide band
sensors and computer systems of course.:wink:
Information sources to learn exactly what you need to know.Last edited by Movin; 04-28-2015, 08:09 PM.Reflex paint by Langeman...Lifted...Tow Rig
