Firewall wire routing...
  • Firewall wire routing...
    Whats the easiest way to route wires to the engine compartment from the passenger compartment?
    I don't like going thru the driver side quarter panel, real PITA to get to from engine compartment...
    1991 Beastiva L BP autoX'er
    Speedo cable opening
    '93 Green L - ' Tiva
      If you don't have A/C, then on the passenger side of the firewall, in the engine bay, you will see two plastic plugs for the A/C lines. In the passenger area, they are covered by carpeting, but that's no problem to just pull away.
        So mine has A/C lines that are no longer in use, they are just sticking through the Firewall. How hard is it to pull them out? I remember trying to take a Festiva Dash apart many years ago when I was just a young lad but did not succeed.
        "The Rusty Banana" 1990 Yellow 5 Speed Mud Festiva (Lifted with 27" BKT Tractor Tires)(Winner of "Best Beater Award" - Madness 12 - 201
          The a/C unit is a separate piece for the Festiva so you can remove the evaporator box without tearing the whole dash out. You will have to loosen it and swing the passenger side out a little though for clearance.
            Cool, probably shed a couple extra pounds that isn't being used.
              Niiice, thanks all!
