aspire spindle stud size?
  • aspire spindle stud size?
    What size is the stud on the aspire spindle? I am about to order my shims inorder to get my car to camber for the race season. I dont know the rear stud size on the spindle.
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
    Should be m10
      If your using the moog shims or the like you cut spots for the studs so it won't really matter what size. If your getting something made , I'm interested!
        The shims come with a paper that shows you where to cut out for the holes on the aspire spindle.
          I will be pressing out the stock studs in the spindle and tapping to the next size up to run a stronger bolt in the rear! I will run my moog shims that i have on my aspire beam.
            I dont understand. The bolts that hold the spindle to the axle? Wouldnt the beam tear off the frame or the springs push through the shock towers before those failed?
