My heat problem is only when the weather turns cold.On a normal summer day the car runs at a normal operating temp. I have replaced the tsat twice, but still won't work when its cold out.I had to replace the head gasket and had the head gone through. Everything is new and shouldn't have a problem.Any ideas?
No heat in the winter?
drain your radiator and flush it, then replace the tstat again. it could probally be gunk in the engine/rad messing with it.2007 Ford Taurus 23-25MPG
1976 Chevy Silverado (my toy)
1951 Ford Deluxe, being rebuilt
Have an old car truck or tractor? Go here.
http://www.aintperfect.com/
Yeah, me thinks b3 madness is on the right trail!
If one of the cable sheathing clips has popped off, then the lever doesn't open or close the appropriate vent!
If you have that much "gunk" in your coolant then you'd have other problems!
Always check the simplest solutions first!'93 Blue 5spd 230K(down for clutch and overall maintanence)
