yeah same here...
oil light
i have the same issue and the solution for me is repair the harness wire that comes from the sensor to the light.Trees aren't kind to me...
So yesterday I got into my festiva went to start it and the battery was dead so I drove to advance auto and picked up a new battery when I got home I hooked it up and the car turned right over. The oil didn't seem to be on any longer so I was ecstatic and I decided to let it idle for a bit and see if it comes back. I returned to the car and still no sign of the oil light so I turned the car off and went inside. Later at night after sundown I got in the car to move it back into the garage and now I noticed the oil light is back on. I am thinking it was on the whole time but possibly it was just to light out to see it during the day time. Either way it is noticabley dimmer now than before.
Sounds like you have an intermittent ground in your wire from the oil pressure sensor to the light. Trace the Yellow with Red stripe wire from the sensor to the connector C101 at the" harness at the left of engine compartment, near Battery"(from the festiva EVTM shop manual). You probably have a worn spot in the wire insulation.1991 L 408,000 miles+ w/NEW B3 longblock!!
2008 Nissan Versa S HB
Ok so I installed an oil pressure gauge and the stock oil pressure light on a brass tee and when I turned on the car the light wasnt on and the engine was idling at about 15 psi of oil pressure. I give it a little gas and the light lights up and it gets brighter the farther in I push the gas pedal and the oil psi raised to about 40. I let it idle and the light stayed lit and the oil psi went down to about 25 when I finally turned the car off.
first, the ground for the sensor is through the engine block, second, it's a harness issue (i promise) take a new wire and connect it to the sensor and then run through the firewall and splice it into the main harness as close to the cluster as you can. the light will go out.Trees aren't kind to me...
