Well i found out today that my VAF doesnt like being on its side. After i put in the cone filter i put it on its side to fit and it started to idle worse and worse. It drove fine just bad idle (jumping and falling all over) i took the VAF out and blew in it on its side i noticed the little door wouldnt close completely all the time. Long story short, fliped it back and it runs fine!.
VAF
yes, VAFs are orientation-sensative. They need to be mounted flat to ensure proper operation, mainly at low rpm (when airflow is weakest)Jim DeAngelis
Mine is mounted on it's side. It was that way when I bought it. I've put about 22,000 miles on it with no problems......1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
Mine is mount srtaight up and down....not many problems here. But when i lengthened the wires for the b8 swap....occationally i have a short cutting off the motor.---------------------------------------------------
