VAF
  • VAF
    Well i found out today that my VAF doesnt like being on its side. After i put in the cone filter i put it on its side to fit and it started to idle worse and worse. It drove fine just bad idle (jumping and falling all over) i took the VAF out and blew in it on its side i noticed the little door wouldnt close completely all the time. Long story short, fliped it back and it runs fine!.
    -Scott
    Aqua 93 L
    Razor Red 09 F-150 XLT
    White 06 Ford Escape XLT
    hm thats weird, that may be why mine had a bad case of idle surge?
      yes, VAFs are orientation-sensative. They need to be mounted flat to ensure proper operation, mainly at low rpm (when airflow is weakest)
      Jim DeAngelis
      kittens give Morbo gas!!
        well now :x maybe thats my problem
          Yeah thats about the angle mine was at.... :roll:
          -Scott
          Aqua 93 L
            were you guys getting any CEL's?
              Mine is mounted on it's side. It was that way when I bought it. I've put about 22,000 miles on it with no problems......
              1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
                No lights. I think due to the fact that as far as the pcu knows the VAF is working right.
                -Scott
                Aqua 93 L
                  Mine is mount srtaight up and down....not many problems here. But when i lengthened the wires for the b8 swap....occationally i have a short cutting off the motor.
                    wow, that is the dirtiest engine bay I have ever seen!
                    White '89L auto - Sold!
                    Silver '06 Rav4, 95k!
                      hay thanks! :lol: thats about 15 years of undercoating built up, probably adds about 100 pounds to the car by now
