You might try doing that cubstiva, it would be easier to hear the pump running w/o the engine cranking plus you could go back and listen by the tank w/o holding the key in crank position. :idea:
some sorta sensor
The connector should be to the right of the master cylinder as you are looking in the bay. There are four or five other connectors there too. I think you want the one with the black wire going to it, but Im not positive about that, maybe someone else will know.sigpic
Freshtiva, Do you have the diagram of the wiring in the engine bay to post. with the fuel pump test connector and the self test? connector.
Yes, that is the fuel pump relay that I replaced. Mine was slightly pitted but still worked ok. I relaced it cause I found a good deal on one, I think on "Advance Auto Parts" on the web, the price was cheaper than in the "Advance Auto parts" store.it runs so sweet
91 L 5spd
^ "Freshtiva, Do you have the diagram of the wiring in the engine bay to post. with the fuel pump test connector and the self test? connector"
No I dont.sigpic
^^ No problem Mike ..
Thank you for those pictures , very nice and useful------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Cool, its just as I thought. I guess I did have a pic of the connector but not the procedure. Im going to make a copy of that.I guess the jumper just completes the ground. What are the color of the two wires going into the connector?? Or is it the only two pin connector ?
Mike, where did you find those pubs? I've got them packed away somewhere, but I was a Ford tech for quite some time....Jim DeAngelis
kittens give Morbo gas!!
Originally posted by 25HorseplayMike has EVERYTHING!!!!!!!!!!!!!!sigpic
