Any one have a chart of the fault codes for the Festiva ? I have this sample chart but "sample" worries me. Also anyone have the non-naao section of a 1992 Power Train Control /Emissions Diagnosis Manual.
Fault codes
Fault codes
Celebrating 25 years of festiva(s) ownership.Tags: None
I Have 92 code info....fORD POWERE TRAIN CONTROL...a hard one to come buy
what you show....right column is the output from the module to the check engine light.
do you want how to obtain the code...STI connector
do you want all the code descriptions]
do you want both...please post
can email imagest. can not link images yet.Joe Lutz
The SKATE ..... 1992L 5spd
Thanks jglutz, I think I know how to obtain the code using a voltmeter. I wish I had a superstar tester and adapter but the voltmeter will work fine. What I was wanting was the one or two digits codes and what the codes represents. Kind of like the chart I posted. 01 = broken wire, 15= oxygen sensor output low, etc. I also want to get the procedures from the 1992 power train control /emissions diagnosis manual for the quick test and the switch monitor test. My email is shadranjohnson@embarqmail.com
phantorn: I'm not getting any code right now I'm just studying my favortie subject, Festivas The self test connectors arent much use unless I know how to use them.sigpic
Ahhhh the favorite subject. It would be cool to have the codes as a sticky. jglutz, to link images upload to photobucket (free). Good luck.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
The codes are in the Haynes manual. After they went with the industry-wide OBD standard sometime in the 90's all you need are the OBD (On Board Diagnostics) codes all the car manufacturers use.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by WmWattThe codes are in the Haynes manual. .sigpic
^ Thank you F3BZ Ive made copies.sigpic
