as long as ur valve seals are good and it is just burning b/c of blow by an oil catch can would save you of burning all of your (uncle festers/lucky's) oil right... still might burn some but not as muh right?
oil catch can....
not Fester. He's not pulling it through the breather.... He's pulling up right past the rings during high vac (decel, idle)Jim DeAngelis
blow by
Yea on one of my festivas I had a huge problem with blow by. I did a head gasket and valve stems seals thinking the problem was something else. Here I had so much blow by that my crankcase was pressurizing and blowing out gaskets. It is my beater festy so all i did was put a hose from the dipstick tube to a bottle. Magically I stopped blowing out seals. Not the correct way, but it works and it stopped leaking oil. And I know your next question, yes the pcv valve is new and the system is clear.just thought i would share my experience. It isn't pretty but it works!
