oil catch can....
  • oil catch can....
    as long as ur valve seals are good and it is just burning b/c of blow by an oil catch can would save you of burning all of your (uncle festers/lucky's) oil right... still might burn some but not as muh right?
    not Fester. He's not pulling it through the breather.... He's pulling up right past the rings during high vac (decel, idle)
    Jim DeAngelis
    kittens give Morbo gas!!
      how do u know that by the plug on the cyc that is leaking??
        all 4cyl..... walls are rusty from sitting...... already got new stem seals, didn't change at all....
        Jim DeAngelis
          blow by
          Yea on one of my festivas I had a huge problem with blow by. I did a head gasket and valve stems seals thinking the problem was something else. Here I had so much blow by that my crankcase was pressurizing and blowing out gaskets. It is my beater festy so all i did was put a hose from the dipstick tube to a bottle. Magically I stopped blowing out seals. Not the correct way, but it works and it stopped leaking oil. And I know your next question, yes the pcv valve is new and the system is clear.just thought i would share my experience. It isn't pretty but it works!
          The new keeper of Uncle Fester!! 88 5-speed, efi, now with ac!
          1988 LX ~sold~
          1992 Blue GL auto, ac ~sold~
          2008 Nissan altima 3.5sl loaded <lease returned>
          1996 Nissan maxima <sold>
          2002 ford f350 crew cab short bed diesel
          Just remember, it could be worse, you could have a fork in your eye!!
