when i start my 93 festiva after it cools off overnight it idles at about 3000rpm for 10 minutes or so till it warms up and gradually drops down to around 1000rpm. any one know how to fix this?
high idle on cold start
On my carburetted engine it's the automatic choke. The engine runs rich until it warms up. I can tap on the gas pedal to release the choke. Also, pumping the gas before starting helps. Could be your temperature sensor or fuel feed? Fuel injected engines have an air flow sensor which also causes problems when it gets dirty and sticks so I've read here.Last edited by WmWatt; 02-05-2019, 08:49 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
my 91 wa festiva did the same thing, revved its heart out until it warmed up, even after it cooled down for an hour it would still do it, it was the auto choke on mine, it has a wax pellet mechanism that releases once it warms up, big issue with that carburetor i hear, the only way to fix is replace the choke mechanism if you can find one i think they stopped using them after that year. i bought a new Weber DFT carb, and had it fitted by the "carby man", not cheap, but runs great now.
What does it normally idle at when it is warm?"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
My warm Idle is about 1000 RPM in my EFI. I am wondering if OP has their warm idle set too high possibly"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
