mysterious seal in gasket set...
    Both of the previous are good guesses...thou I would go with the later because on several rebuilds they always show it in the upper/head set.
    Joe Lutz
    The SKATE ..... 1992L 5spd
      so, its not a rear main seal... thats eliminated..
      -Aspire brake swap COMPLETE!
        ^^Yep...I had the same extra...never found a home for it...my rebuild 1992L stock.
        Joe Lutz
          could this be for the aspire only???
            My 1.9 Escort and 1.6 Miata gasket kits both came with extra gaskets. Im sure its cheaper to just add a few gaskets than make a whoile set for a different car, if they both use similar engines.
            Plus, the orange looks familiar, it may be something I used on the Miata.
            Joey
            As he was perfectly drifting past the apex I looked at Quasimofo and yelled "You know, I have never been in a rollover accident before!"... I think it all went pretty well after that.
