12 inch wheels?
Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
Genevadirt wrote:
The 155-13s are 1/2 inch taller than the 155-12s, so they will slow your speedo down quite a bit. The tire section is indeed the same, but the wheel is one inch larger diameter. Thus, from the hub center to the ground it would be half an inch taller in ride height.The 155/80-13 should nolt give you a flase reading on your speedo....same size tire as the 155r12...center is only differance.
Double check this by going to Tire Rack and checking the Kumho specs for 155/80-12 and 155/80-13. The first is 21.8" overall diameter vs. 22.8" OD for the 13" version.
The Yoko AVS ES100 in 185/60-14 was 22.7" in OD.
Now compare this to the stock Festiva 145/80-12 size (Yoko Y732) tire OD at 21.5".
The larger two tires are thus 1.5" larger diameter, making them about 3/4" taller in ride height.
i checked this site out, not bad.Originally posted by LittleBlue2I know Tire Rack is out of Kumhos right now, but go to www.tires-easy.com and put in 155 80 12 and you will get three selections and it appears they now have Kumhos in stock now. (Didn't have them last week when I ordered)
thanks for the info.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
i just got a set of kumho's for $27 each, or if you have a wal mart i saw that 12's are $20 each but i don't know how good of quality they are.Originally posted by MPG View PostTire Rack still has the OEM Yokohama's for $51 each.1972 Ford Gran Torino Sport(Sold)
1999 Ford Mustang Gt 35th ann. (Sold)
1993 Ford Festiva Gl(Sold)
Looking for another Festiva
Sorry, I forgot that there were two different stock tire sizes. The 165/70-12's are available at Tire Rack.Originally posted by Pu241 View PostNot actually available!
Had a set of 4 ordered for my wife's car for 3-4 months and finally canceled the order as they couldn't tell me when or if they were ever going to get them in!
What size Kumho's, the 155/80-12?Originally posted by rerhard View Posti just got a set of kumho's for $27 each, or if you have a wal mart i saw that 12's are $20 each but i don't know how good of quality they are.
I checked Wallyworld and they don't have the 155/80's or the 165/70's.
I also found that Summit Racing has the 165/70 Yoko's for $50 with flat $10 shipping.
Guys, you know the base model stock tire size was 145/80-12, don't you?
Try all the following:
145/80-12 stock base model tire, on 4.0 wide rims
165/70-12 LX and GL stock tire on 4.5" wide rims (steel and alloy)
155/80-13 is the most common replacement size
There are one or two other odd 12" sizes for original Minis which are sometimes seen but probably not suitable for our cars.
I'm rather proud of this: I'm one of the main reasons the Kauffman locations in my area (Lawrenceville, GA) carry 12 inchers. They were actually discussing it at a meeting, and the manager of the location I usually hit mentioned that they had "this guy with a Festiva that's been a customer for ages," and so they needed to keep 12's available.
Amazing what 10 years or so as a customer can do...93 Festy GL, 144K and goin strong!
