Picked up my '92, 5 speed, from the farm a couple days ago. Ran flippin' great, but leaked about a quart of oil in 45 miles. Did a thorough cleaning job and oil is leaking from the front of the motor, below the cam seal but above the crank seal. Went and got all gaskets, oil pan, crank seal, not sure if the cam seal came with it, but will replace it and the valve cover gasket, and then the gasket that sits behind the crankshaft pulley(I'm so tired right now I can't remember the name and it's the one that I think is leaking).
Anyways, the timing belt cover had already been removed, so I'm wondering if the timing belt has been replaced. I soldier on and line up the crankshaft pulley slot to the arrow on the block. When I do this, the camshaft marks at 12 and 3 appear to be one tooth off to the right. Do I leave it and make a couple new marks or when I put it back together, do I align the 12 and 3, plus the crank pulley at 12?
This is the car that goes to the DJ Midwest Meet if at all possible and I have one shot to do this right. There is so much flippin' work to do and I started back to work today.....good, but not good.
