Ive found a low mileage aspire 1.3 motor that Im thinking about buying. Just wondered if any one had some info I should know about putting one in a festiva. Dont know if the previos car had an auto of manual tranny.... Ill have better info tomorrow. Thought maybe the ECU and or other wiring might be a problem. Any input is appreciated.!! Thanks !
94/95 aspire motor
94/95 aspire motor
Celebrating 25 years of festiva(s) ownership.Tags: None
ECU should not be a problem. Autos and manual ECUs are the same, at least with OBD-1.
TPS is probably transaxle specific. Mine was when I did my B6 swap. My auto harness did not directly fit my auto B6 TPS, so I swapped in a '91 Protege 5 speed TB.
I think if you use the Festiva B3 intake and exhaust manifolds and air plenum/TB on the Aspire engine, you should have little to no trouble with this swap.
I do know there was a change in the valve cover and VC bolts either from the Festiva to the Aspire, or during some model year of the Aspire. I broke a VC bolt during my '94 323 B6 install and a Festiva VC bolt would not work. I found a replacement off an Aspire B3.
The bolt and washer setup was different.
Do a thorough eyeball exam on both setups and you may see some differences, but they should be readily surmountable with minor swapping of small parts.
I think the right side engine mounts are the same. Someone correct me if I'm wrong.
What about the drive belts, isnt the aspire different ? Seems like it uses a flat belt instead of a v belt. Are the drive pulleys interchangable from the aspire to the festiva ? Will the festiva pulley attach to the aspire crank ? Other wise Id need to change the pulley on the water pump and alt. and a/c ??sigpic
Hey Fresh,
Is there an advantage to swapping to that motor or did you just get it at a price that makes it worth swapping?ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Im just getting it for an extra since its low mileage. But I think the the aspire has roller cam/rocker arm set up. Thats probably an improvement over the festiva B3. There may be some other small things too.sigpic
I think you may want to use the festiva exhaust manifold. I believe they flow better than the aspire ones. I remember this being a big discussion a few years ago. Something about the aspire one being more restrictive to bring down the horsepower.The Festiva Store
if the $$'s are right...go for it
Even if it has a few crossover issues...think about what a crank...con rods...pistons...cam...or...head would cost...with your fleet, its probalbly worth its value in parts.Joe Lutz
The SKATE ..... 1992L 5spd
^ good advise, I found the engine because I was looking at a rebuilt head for my car Jerry. It alone is over $200. I can get the whole motor for just a little more. I think its going to be delivered too. Seems the seller passes by on a regular basis. Ive got one good spare motor but Im thinking years down the line. Id like to drive a festiva the rest of my life.sigpic
God Bless You! I love my festiva and want to own it the rest of my life....but have some affection for the rest of my beat fleet.Originally posted by freshtiva View Post.... Id like to drive a festiva the rest of my life.Joe Lutz
Can't go wrong,go for it!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
^ what else do you have in the "beat fleet" ??sigpic
same here, i'll call it my casket on wheels :lol:Originally posted by freshtiva View PostId like to drive a festiva the rest of my life.
"Casket on wheels."
I LOVE THAT!!
I'd like to be buried in a Funtop, with the top left open. Let the dirt shine in!
Besides, worms gotta eat too!
