Ive found a low mileage aspire 1.3 motor that Im thinking about buying. Just wondered if any one had some info I should know about putting one in a festiva. Dont know if the previos car had an auto of manual tranny.... Ill have better info tomorrow. Thought maybe the ECU and or other wiring might be a problem. Any input is appreciated.!! Thanks !
94/95 aspire motor
94/95 aspire motor
Celebrating 25 years of festiva(s) ownership.Tags: None
ECU should not be a problem. Autos and manual ECUs are the same, at least with OBD-1.
TPS is probably transaxle specific. Mine was when I did my B6 swap. My auto harness did not directly fit my auto B6 TPS, so I swapped in a '91 Protege 5 speed TB.
I think if you use the Festiva B3 intake and exhaust manifolds and air plenum/TB on the Aspire engine, you should have little to no trouble with this swap.
I do know there was a change in the valve cover and VC bolts either from the Festiva to the Aspire, or during some model year of the Aspire. I broke a VC bolt during my '94 323 B6 install and a Festiva VC bolt would not work. I found a replacement off an Aspire B3.
The bolt and washer setup was different.
Do a thorough eyeball exam on both setups and you may see some differences, but they should be readily surmountable with minor swapping of small parts.
I think the right side engine mounts are the same. Someone correct me if I'm wrong.
What about the drive belts, isnt the aspire different ? Seems like it uses a flat belt instead of a v belt. Are the drive pulleys interchangable from the aspire to the festiva ? Will the festiva pulley attach to the aspire crank ? Other wise Id need to change the pulley on the water pump and alt. and a/c ??sigpic
Hey Fresh,
Is there an advantage to swapping to that motor or did you just get it at a price that makes it worth swapping?ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Im just getting it for an extra since its low mileage. But I think the the aspire has roller cam/rocker arm set up. Thats probably an improvement over the festiva B3. There may be some other small things too.sigpic
I think you may want to use the festiva exhaust manifold. I believe they flow better than the aspire ones. I remember this being a big discussion a few years ago. Something about the aspire one being more restrictive to bring down the horsepower.The Festiva Store
if the $$'s are right...go for it
Even if it has a few crossover issues...think about what a crank...con rods...pistons...cam...or...head would cost...with your fleet, its probalbly worth its value in parts.Joe Lutz
The SKATE ..... 1992L 5spd
^ good advise, I found the engine because I was looking at a rebuilt head for my car Jerry. It alone is over $200. I can get the whole motor for just a little more. I think its going to be delivered too. Seems the seller passes by on a regular basis. Ive got one good spare motor but Im thinking years down the line. Id like to drive a festiva the rest of my life.sigpic
Originally posted by freshtiva View Post.... Id like to drive a festiva the rest of my life.Joe Lutz
Originally posted by freshtiva View PostId like to drive a festiva the rest of my life.
Me too!
Can't go wrong,go for it!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
^ what else do you have in the "beat fleet" ??sigpic
"Casket on wheels."
I LOVE THAT!!
I'd like to be buried in a Funtop, with the top left open. Let the dirt shine in!
Besides, worms gotta eat too!
