or use carb cleaner to find a leak. If its sucked in then the idle will drop.
Rough runner
Sounds like the vacuum advance is bad to me too. You should get a vacuum pump (mityvac or similar) then check the can on the distributor .. the one with two hoses connected to it. Make sure that it holds vacuum and does not leak air. Unfortunately the part is hard to find and expensive as a new part. Good luck!I'm going to come at you like a spider monkey!
White 1993 L plus, 5 speed - 47k miles
* Aspire brake swap, 14" Miata wheels & Tein coliover suspension
Starter fluid will work. Actually anything flammable will work.Originally posted by MONSOON View Post...Although the starter fluid trick might work(someone may confirm this). I didnt want to say thats what he said when it wasnt.
I like the propane torch idea.Festiva: Because even my dog can build a Honda.
88' LX EMERGENSTEVIA
