Easiest way to replace clutch ??
  • #16
    GenevaDirt , haven't heard from you .Did u get my number ??
    • #17
      Originally posted by bhazard View Post
      How much does a B3 weigh? Pull it by hand!
      the B3 can be lifted out by hand but it would be a royal pain to line it back up when re-installing
      • #18
        you can drop the trans from beneath and support the motor with a 2x4...
        89SX funtop! Fully loaded!
        RIP 90LX
        • #19
          Had mine out....picked it up with my hands and set it back in place while the wife ran the passenger side craddle bolt in....once in...I dropped the tail end down onto a block.
          IMO...there is no reason to consider pulling the block to change a clutch
          Joe Lutz
          The SKATE ..... 1992L 5spd
          • #20
            Soooo,is it easier for a first-timer to pull the engine or drop the tranny ? Which one is the quickest ??Any other things I need to know about ? I have the HAYNES and the sticky's from here copied.
            • #21
              X2
              Especially since the trans is relatively easy to remove, and unbelievably light.
              Axlander9289, brother of ThisVelologist
              Festivas past:
              Aqua '92 Festiva L - Sold "Dale"
              White '89 Festiva L Plus - RIP "Dudley"
              White '93 Festiva GL - Sold to thisvelologist "Frito"
              Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
              Current Fleet:
              Aqua '93 Festiva L with Aspire brakes "Dale Jr."
              Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
              White '15 Ford Transit Connect
              • #22
                as stated....I prefer not to lay on the floor or in the dirt and gravel messing with the tranny when I can remove some bolts and wires and use a cherry picker to pull the engine out. Then when it is out you can clean the engine....go over it and replace any gaskets with ease. Change the water pump...ect.... To me it is much easier to work on that stuff while it is hanging out in the open.
                • #23
                  i agree with genevadirt... i dont want to roll around on my back, but then again i do this stuff for a living and am spoiled now. i dont even change my oil on the ground. these cars are so light that every thing is easy, compared to other cars. if you have air tools and such, and a garage, then its all a matter of personal prefference. although it would be good for a novice to do the tranny on there back. it kinda weeds out those who wouldn't last any way. kinda like a right of passage.
                  Neil
                  Jesus loves me. This I know.
                  93 L track prep in progress
                  88? Parts car-sold
                  86 b2000- pisses of HOA-sold
                  • #24
                    Both ways are not that bad. I prefer the tranny way myself because I can do it in an hour. If you pull the engine, you will be dealing with more wires, but each one has there ups and downs. If you are getting help, do it the way the other person wants to do it. If you decide to pull the tranny, you could use a car jack and a block of wood to support the engine. If you do it this way it helps because you can then also lower the engine to make tranny removal and installation easier.
                    The Festiva Store
                    • #25
                      i think someone should start a poll on this.
                      87 rx7
                      92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
                      94 caddi deville
                      99 f250 LD 4x4 12 inch lift on 38s
                      i need more festies.
                      • #26
                        OK,so,I found and printed the paperwork on tranny removal,but,I cannot seem to find one on just removing the engine.NE1?
                        • #27
                          Pulling the engine requires pulling these extras
                          Coolant lines (4X)
                          fuel lines
                          Air ducts
                          front motor mount bolt
                          Main electrical harness
                          Throttle cable
                          Misc vac lines
                          Alt. power cable.
                          A/C if equiped.
                          IMO....I'd rather lay in the mud.
                          Joe Lutz
